3
[Submitted] Known Issues for OnePlus 6/6t
  1. Abdulbasithmh software Operations Staff Member OnePlus Bug Hunter Apr 1, 2019
    Abdulbasithmh, Apr 1, 2019 :
    Hey everyone,
    We're listing the known issues that we are currently working for the current version of the open beta and stable builds for OnePlus 6 and 6T Devices.
    vermgau, konomasa and AnonymousWP like this.
  2. Abdulbasithmh software Operations Staff Member OnePlus Bug Hunter Apr 1, 2019
    Stickied Post
    Issues reported in the Open Beta version 190429:
    • Speed dial issue. When calling someone from the speed dial list, the Wrong number is called.
    • Battery drain and Heating issue
    • Shelf Doesn't Retain the Scrolled state when Swiped from homescreen.
    Our team is trying to reproduce and fix this reported issues, if you are facing any of this above issues please help us by reporting the issue via the newly introduced feedback section in community app or in the forum feedback section, so we can have more valid logs to analyze and fix the issue ASAP.
    Thank you
    Tonino71 and AnonymousWP like this.
  3. Abdulbasithmh software Operations Staff Member OnePlus Bug Hunter Apr 1, 2019
    Stickied Post
    Issues reported on the Stable version 190403:
    1. Apps get killed in the background/ Poor Ram management.
    2. battery drain and Heating issue
    3. Slow performance and lagging issue
    4. Glitching in YouTube: the black bar area on the side Glitches
    Fixed issue:
    • the Weather app keeps crashing when the setting is selected from the top right corner.
    • Speed dial gets automatically cleared Randomly
    Solution: update the Weather application from Playstore.
    Fixed issues(in next version):
    • Native Message app doesn't support auto-rotate
    Thank you
  4. guruni Cupcake Apr 7, 2019
    guruni, Apr 7, 2019 :
    I have an issue with my microphone, I have to put on speaker when talking on the phone otherwise nobody can't hear me
  5. TeMpL Gingerbread Apr 8, 2019
    TeMpL, Apr 8, 2019 :
    Night / daylight mimo does not alwas change.. (set to "auto")
  6. alexansBROS Froyo Apr 9, 2019
    alexansBROS, Apr 9, 2019 :
    As you can see 32 % of battery drain in 11 hours of screen off. This is absolutely crazy, and this is stressing, heating and destroying my battery.
    Now it's 2.5 months that there is this problem, and the situation is unacceptable for a flagship.
    OP6 190123
    Tonino71 and J1550993466285 like this.
  7. J1550993466285 Cupcake Apr 11, 2019
    J1550993466285, Apr 11, 2019 :
    This is 6t's the most calm state,I mean I disabled many app and limited any background and foreground app and you can see all cores active,and phone can't go deep sleep for this CPU hotplug.Wasting much power when it screen off.And when i go another apps it using %80 of it's capacity.Small cluster %100 and big one %90.Do better kernel optimizations for this monster,we don't want impossible thing,we want performance with a good battery life,and ram is generally %80 using,you must clear unnecessary processes.Camera need much improvement not good on 4k60fps and Selfies.If I don't take a update for this problems I never try and suggest this brand again.
  8. vixcrack Eclair Apr 19, 2019
    F1553756967337 and Abdulbasithmh like this.
  9. F_Rahul_Bhargav_tfjG Cupcake Apr 26, 2019
    F_Rahul_Bhargav_tfjG, Apr 26, 2019 :
    I have purchased big brand phone OnePlus 6t only one day before, I have an issue my phone is hanging problem Everytime again an aging plz resolve this problem.
  10. Anu__Saira__ Cupcake Apr 26, 2019
    Anu__Saira__, Apr 26, 2019 :
    •*speed dial*
    Speed dial keeps getting refreshed every day, instead of changing according to our frequently called. it just disappears. It is very annoying, to go to contacts and find those contacts when we've been using the speed dial so often.
  11. T1541374325810 Cupcake Apr 27, 2019
    T1541374325810, Apr 27, 2019 :
    Problems with accidental screenshots : My left thumb naturally falls to the Volume Down button while my Middle finger rests on the Power button. This Naturally results in random screenshots especially when I turn the screen Off with my Naturally Placed middle finger. Maybe it's just me ... ? Thank You V Much for this Feedback area ‼️
    Y1557541702977 likes this.
  12. T1541374325810 Cupcake Apr 27, 2019
    J1550993466285 likes this.
  13. T1541374325810 Cupcake Apr 27, 2019
  14. V1556693007370 Cupcake May 1, 2019
    V1556693007370, May 1, 2019 :
    I just bought a new oneplus6T McLaren edition.
    the issue is still the same which was unresolved with my Oneplus5.
    issue in video screen mirror/casting.
    there's a major issue in trying to cast my device on to any smart TV. it generally takes too long, And sometimes doesn't connect at all.
    when it finally connects. everything mirrors perfectly but
    THE VIDEOS don't mirror/cast on to other devices and that(video) window in the screens just shows a blank black window.
    this is a major major problem when I'm trying to screen the latest episode of GoT onto my TV.
    please help!
  15. AryanDhanraj Cupcake May 2, 2019
    AryanDhanraj, May 2, 2019 :
    I am an owner of OnePlus 6t and I have been facing an issue in my handset. Sometimes when a notification arrives and when the ambient display turns on then if immediately I put my fingerprint the phone stops to respond and the screen blacks out. Then after 5-6 second the phone performs normally.
    adi1001 likes this.
  16. vermgau Cupcake May 4, 2019
    vermgau, May 4, 2019 :
    Facing issue with Battery heating up and draining. Already tried cleaning up cache and factory reset.
    Tonino71 and adi1001 like this.
  17. F1556638044135 Cupcake May 4, 2019
    F1556638044135, May 4, 2019 :
    From past two updates including the latest one. I am facing heating issue while watching YouTube and also while charging. I recently spoke with one plus customer care executive and they told me to do two things, wipe cache and reboot which didn't help me. Every time I see this message and it's not going if i swipe it.
  18. Phlapis Cupcake May 4, 2019
    Phlapis, May 4, 2019 :
    While usind 3d party launchers like nova or apex phone app goes background (minimize) and only notification icon stays on the panel. If you want to see call UI you should press that icon. This is happening with making or receiving call and is very annoying. It has started with phone app v. 4.2.0
    T1541374325810 likes this.
  19. JungleElephant Cupcake May 5, 2019
    JungleElephant, May 5, 2019 :
    remove the small blue annoying dots next to the app icon. and some of the them are keep popping up when I get new emails in the email app. cannot remove..
  20. Kabeer_Pande Eclair May 9, 2019
    adi1001 likes this.
