13
[Submitted] Known Issues for OnePlus 6/6t
  1. Abdul B.
    OxygenOS Operations Staff Member Aug 30, 2019
    Abdul B. , Aug 30, 2019 :
    Hey everyone,
    We are listing the known issues that we are currently working for the current version of the open beta and stable builds for OnePlus 6 and 6T Devices.
    _gahan, DrJMun, german640 and 10 others like this.
  2. Abdul B.
    Stickied Post
    Issues reported on the Stable version 190801:
    1. unable to download the applications via Playstore
    2. System Lag
    3. Battery Drain and Heating Issue
    Fixed issues:
    Andriod Auto Crash issue
    Our team is trying to reproduce and fix this reported issues, if you are facing any of this above issues please help us by reporting the issue via the newly introduced feedback section in community app or in the forum feedback section, so we can have more valid logs to analyze and fix the issue ASAP.
  3. Abdul B.
    Issues reported in the Open Beta version 190807:
    • Spotify app being killed in the background
    • Speed Dial calls incorrect number
    Thank you
  4. S155
    Ice Cream Sandwich Aug 31, 2019
  5. R1565327305229
    Cupcake Sep 3, 2019
    Z1519482444490 likes this.
  6. Q1530347105795
    Eclair Sep 3, 2019
    Q1530347105795 , Sep 3, 2019 :
    Android Auto crashing on start-up still seems to be an issue. Not sure whether this is the issue that has supposedly been fixed (the AA developers say it has been referred to OnePlus) but it is still ongoing for me (OP6, OxygenOS 9.0.8)
  7. somenothingness
    Honeycomb Sep 18, 2019
    somenothingness , Sep 18, 2019 :
    Whenever using any music app, whether Bluetooth or wired, the audio tuner settings are not active unless the audio tuner is first opened.
    That is to say that if I want the stock equalizer to work I must open the music app then open the audio tuner. Even when enabled, the audio EQ is not active unless I open it first.
    This must be done each time a new connection is made or re-established or a music app is closed and reopened.
  8. A1569072142617
    Cupcake Sep 21, 2019
    A1569072142617 , Sep 21, 2019 :
    My OnePlus 6t just started to slow down I don't know wether it's becouse of the coming update or something please update if I need to do rectify this problem
  9. Viren19
    Cupcake Sep 27, 2019
    Viren19 , Sep 27, 2019 :
    After updating with latest open beta release in my OP6, I am facing one alarm and other calling issue.
    1. Alarm is not ringing and showing missed alarm notification.
    2. Not able to make second call or receive additional call.
  10. jpxdude
    Froyo Sep 27, 2019
    jpxdude , Sep 27, 2019 :
    Hi there,
    I'd like to report a bug that's not been resolved Since the 6T was released.
    If I use the Google Assistant using my voice (saying Hey Google or OK Google) the screen stays on indefinitely. One common use case is when I have the phone on the night stand and I ask Google Assistant something (play some music, what is the weather like tomorrow etc.) That's when the screen stays on.
    I've woken up in the middle of the night several times with the bright light of the screen still on hours later. Please fix this.
    AusomBabs and Elohhim like this.
  11. RANJAN_3229
    RANJAN_3229 , Sep 27, 2019 :
    Hi OnePlus team,
    After latest updates I'm facing sometimes the call app is not working & Even call connection ...not hearing properly. Some sound in speaker... It's just a 3months New OnePlus 6t Mobile phone ... kindly sort out it pls.
    I1541485960480 likes this.
  12. H1557058226130
    Gingerbread Sep 28, 2019
  13. AnotherDanny
    Cupcake Oct 2, 2019
    AnotherDanny , Oct 2, 2019 :
    keep having an issue where the phone freezes, a pop-up saying "system UI is not responding". I have to power off, which takes about 30seconds. then wait a minute before I can power the phone back on.
    this usually happens when I swipe up and open the app manager to close apps.
  14. Berelo
    Cupcake Oct 9, 2019
    Berelo , Oct 9, 2019 :
    I have same problem after 0.17 update and also battery performance was great but it bacame bad after update.
  15. Sekhar AV
    Cupcake Oct 11, 2019
    Sekhar AV , via OnePlus 6T , Oct 11, 2019 :
    i am facing issue during video calls sound coming out on speaker is very low even if i put on high volume.
    does anyone facing the same issue???
  16. SirLost
    Cupcake Oct 14, 2019
    SirLost , Oct 14, 2019 :
    Android Auto crashes for me on startup still. This is silly. I'm starting to hate this phone.
  17. darkwingz
    Froyo Oct 14, 2019
    darkwingz , Oct 14, 2019 :
    Getting a loud beep on loudspear when call ends in OnePlus 6 Oxygen OS version 9.0.9.
    Do we have any update on that as there has been pending issue for more than 2 months:
    https://forums.oneplus.com/threads/end-call-gives-a-loud-beep-sound-through-speaker.1078808/
    https://forums.oneplus.com/conversations/call-end-beep-is-heard-on-loud-speaker.1551583/
    https://forums.oneplus.com/threads/end-call-sound-loud-even-in-silent-or-vibration-mode.1067685/
    Can someone help to get a response on this issue?
  18. pkray01
    Donut Oct 16, 2019
  19. F1571737675539
    Cupcake Oct 22, 2019
  20. Jolannn
    Cupcake Oct 23, 2019
    I1570907413685 likes this.
