13
[Submitted] Known Issues for OnePlus 6/6t
  1. zyonee
    Cupcake Oct 24, 2019
    zyonee , Oct 24, 2019 :
    On OP6 Android 10, opening my flip case lid will turn on the screen normally, however, closing the lid does not turn off the screen.
    Kutlo likes this.
  2. PeterKocsis
    PeterKocsis , via OnePlus 6T , Oct 24, 2019 :
    Phone:
    OnePlus 6T
    Oxygen OS version:
    OP6T_O2_BETA_30
    Build number:
    A6013_41_191008
    Issue:
    •Auto rotation function doesn't work after updating
    Issue fixed:
    •Issue has been fixed by restarting the phone
  3. r.prvnraj
    r.prvnraj , via OnePlus 6T , Oct 24, 2019 :
    facing same problem... performance issue in calling app while hang-up. taking long time to hang-up.
  4. kuruz
    kuruz , Oct 24, 2019 :
    Phone: OnePlus 6
    OxygenOS version: OP6_02_BETA_30
    Android version: 10
    Build number: A6000_20_191008
    Problems:
    - Facebook Messenger sound cannot be turned off. I set the notifications for it to "important", as I want to see, but not the hear them, but no matter how many times I changed the sound to "none", it reverts back to "app provided sound". I had to set the FB Messenger notifications to "other" in order to avoid the sound every time I receive a message, but I don't want it like that - I need them in the status bar and on the ambient display, just as it worked on Pie;
    - screenshot notification cannot be changed to "important", which means that I no longer see it in the status bar and it's only visible when I swipe down. It's also not visible on the ambient display;
    - Telegram notifications are waking up the display and I cannot find an option to turn that off. Ambient display is turned on and lift-to-wake option is also set, but I don't want the display to flash every time a message arrives;
    - PlayStore notifications cannot be set to "important", which means that I don't see that updates are available unless I swipe down or check if there's a notification dot.
  5. H1557058226130
    Gingerbread Oct 25, 2019
    H1557058226130 , via OnePlus 6T , Oct 25, 2019 :
    ALL SENSORS RUNNING WITH SOFTWARE ERRORS,
    THANKS TO ADD HIDDEN SPACE OPENING ,
    PLZ UPDATE VIDEO ENHANCER OPTION ITS MORE USEFUL ,
    CAMERA FAILED TO FOCUSING OBJECTS WHEN IN CAMER MODE.. ITS WORKING ON PRO MODE , FIX ISSUE,
    NETWORK , CALL DISCONNECTED SUDDENLY ,
    SUDDENLY DISPLAY STRUCK,
    LITTLE BIT CRACKING SOUNDS FROM SPEAKER GRILLS WHEN PLAYING MUSICAL TRACKS ,
    HOPE FIX SOFTWARE ISSUES ,,
    WE ARE IRRETATING WITH ONEPLUS 6T , SOFTWARE ISSUES FROM PAST 60 DAYS , NO SECURITY UPDATES .. STILL LATEST BETA UPDATE ALSO FULL OF BUGGS ...
    I THINK ONEPLUS MAGER FAILURE BETA UPDATE IN 2019 ..
    HOPE FIX issuer as early as possible with perfect updates
    WE ARE WATING #[e]2665[/e]️INDIA[e]2665[/e]️ONEPLUS#
    HOW TO ENABLE STEP COUNTER.. # ONEPLUS 6T
  6. Ombra6T
    Cupcake Oct 25, 2019
    Ombra6T , Oct 25, 2019 :
    Hello
    Oneplus 6t updated to Android 10 I found no problems, however there are some small things to fix.
    1) Keyboard that does not fit on the display edge making it higher in Oneplus or google gesture mode even hiding the bar at the bottom.
    2) The google gestures work well apart from the central lower bar which does not adapt the color in the various apps but becomes a white line on the display.
    3) Brightness sensor in automatic mode is very slow in changing the light both increasing and decreasing depending on the light conditions, sometimes it remains with the brightness totally at 0.
    4) The possibility of hiding the Notch is missing
    For now I find these small problems and if there are others I will report them.
    cabrowne likes this.
  7. Fatiguitas
    Cupcake Oct 26, 2019
    Fatiguitas , Oct 26, 2019 :
    Phone:
    OnePlus 6T
    Oxygen OS version:
    OP6T_O2_BETA_30
    Build number:
    A6013_41_191008
    BUG: Access point is not sharing data, it enables, connect devices but cannot navigate.
    Ryu_Hayabusa_Listing likes this.
  8. S155
    Ice Cream Sandwich Oct 26, 2019
  9. guihero
    Froyo Oct 28, 2019
    guihero , Oct 28, 2019 :
    Phone: OnePlus 6
    Android version: 10
    Ma remontée des bugs sur la beta Android 10 du OnePlus 6 :
    - le double tap pour mettre en veille le tél fonctionne un peu trop bien, le tél a bcp de mal à se réveiller ensuite
    - L'application "Android System Webview" tente de se maj depuis le playstore mais sans succès, l'installation n'arrive pas à se faire
    - La barre blanche en base de l'écran sur certaines applis
    - La barre google qui passe du noir au blanc sans aucune logique malgré le thème sombre oneplus
    - Quelques force close sur des applis
    - La messagerie vocale visuelle impossible à configurer sur le réseau Orange France
  10. djkarlos
    Cupcake Oct 28, 2019
    djkarlos , Oct 28, 2019 :
    I have suddenly started getting problems with Android Auto where it seems to crash on startup on the phone, but it seems on the 3rd attempt it sometimes works then works. However this morning connected to the car it wouldn't startup at all and I tried unplugging multiple times and even tried starting it on the phone first, where after a few attempts it starts but as soon as I plug it into the car it terminates.
    Running build A6013_41_190911
    AA version 4.7.59.3824-release
  11. MarkMessinger
    Gingerbread Oct 28, 2019
    MarkMessinger , Oct 28, 2019 :
    I am seeing this same behavior, but on a OnePlus 6 running Android 9.
    Running build A6003_22_190911 (OxygenOS 9.0.9)
    AA version 4.7.593824-release
  12. MarkMessinger
    I have found AA version 4.5.592854 works well. For the time being, I'm not allowing Google Play Store to update from that older version.
  13. DenyDarko
    Honeycomb Oct 29, 2019
  14. Jlastick
    Cupcake Nov 1, 2019
    Jlastick , Nov 1, 2019 :
    Just starting having this exact issue. OnePlus 6
  15. M1508061717556
    Donut Nov 4, 2019
    M1508061717556 , Nov 4, 2019 :
    Oneplus 6T Android 10 bugs.
    1. Touch vibrations automatically change to "hard" after some time even if "light" is selected.
    2. Can't expand WhatsApp messages in landscape mode.
    3. Fingerprint Animations persists on the home screen even after the screen unlocks.
  16. michaelsage
    Donut Nov 5, 2019
    michaelsage , Nov 5, 2019 :
    OnePlus 6
    1. Google Pay no longer works with a software requirements error
    UK based
    (A6003_22_191027)
    cBorisa and Ryu_Hayabusa_Listing like this.
  17. Cervi
    Froyo Nov 5, 2019
    Cervi , Nov 5, 2019 :
    OnePlus 6T
    Direct Dial widget (native, from Contacts) renders "Permission denied" watermark message at bottom of the screen.
  18. H1550338793757
    Cupcake Nov 5, 2019
    H1550338793757 , via OnePlus 6 , Nov 5, 2019 :
    Phone: OnePlus 6
    Android 10 OTA
    Some problems after update:
    1. Display no wake up after lift up
    2. Proximity sensor work incorrect
    3. This application installing about 3 hours and not installed
    #38
  19. Floy3D
    Cupcake Nov 5, 2019
    #39
  20. #40
    jeffluckett likes this.
