6
[Submitted] Known Issues for OnePlus 6/6t
  1. cyjlolz
    Donut Nov 12, 2019
    cyjlolz , via OnePlus 6 , Nov 12, 2019 :
    thanks. but i alrdy downgraded to android pie. hopefully all these issue can be fixed soon.
    #61
  2. splinter_head
    Ice Cream Sandwich Nov 12, 2019
    splinter_head , Nov 12, 2019 :
    I can help with point 3 as it happened to me (If you are still seeing it)
    - Cancel the download
    - Force Close Play Store
    - Clear Play Store's cache
    - Restart the download
    #62
  3. R1573712808299
    Cupcake Nov 14, 2019
    #63
  4. KevinM23
    Donut Nov 14, 2019
    KevinM23 , Nov 14, 2019 :
    Hi,
    I found the solution for the problem with the battery. The issue is caused by Whatsapp. You need to update your whatsapp manually to the newest version which can be downloaded here:
    https://www.whatsapp.com/android/
    Download whatsapp from there, install it and the battery issues will be gone. I did this yesterday and after the update the battery works normally again. After 8 hours sleeping with the phone on, it went from 100% to 95% instead of 100% to 60% so the problem seems fixed.
    I hope this helps more people!
    #64
    Q1544952836228 likes this.
  5. Kafi.bd
    Donut Nov 15, 2019
    Kafi.bd , via OnePlus 6 , Nov 15, 2019 :
    Hello!
    I am using oneplus 6 right now. I have captured several images with stockcam and gcam. Both the images are not sharp. When i zoom in after taking pictures, the pictures are not sharp.
    Is there any slotuion?
    Currently, i am using OP6_O2_Beta_30
    Regards.
    #65
  6. Vatsal_d
    Cupcake Nov 15, 2019
    #66
  7. Rob G
    Eclair Nov 15, 2019
    Rob G , via OnePlus 6T , Nov 15, 2019 :
    Facing an issue of losing signal /connection to mobile network. My SIM card isnt recognised. Reboot wont fix. Have to wipe cache partition every time it happens.
    Phone details below.
    #67
  8. Rainier
    Cupcake Nov 18, 2019
    Rainier , Nov 18, 2019 :
    Hi All, I see om the One+ 6 update a6003_22_191027 several reboots in pocket mode.
    #68
  9. H1557058226130
    Froyo Nov 21, 2019
    #69
  10. Asmir0000
    Cupcake Nov 21, 2019
    Asmir0000 , Nov 21, 2019 :
    OnePlus 6 Upgraded to Android 10:
    Bluetooth does not want to pair with car radio properly.
    After restarting both, the phone connects but you can not play any media, only use it for calls.
    #70
    SpartaKurd likes this.
  11. SpartaKurd
    Donut Dec 1, 2019
    SpartaKurd , Dec 1, 2019 :
    I'm experiencing the same problem. Please fix it soon.
    #71
  12. I1573918825939
    Cupcake Dec 1, 2019
    I1573918825939 , via OnePlus 6T , Dec 1, 2019 :
    camera performance in normal mode is better than night mode in dark situation
    and sometimes apps need to uninstall and reinstall
    this only causes after updated to beta version of Android 10
    #72
  13. O1542672535986
    Donut Dec 1, 2019
    #73
  14. Tee_Eee_Bee
    Donut Dec 2, 2019
    Tee_Eee_Bee , Dec 2, 2019 :
    Only issue is some apps don't like the "Override force-dark" setting being on - Facebook and Calendar being the worst offenders.
    Not sure if the apps need updating (I do regularly update my apps) or if it's this OB version.
    #74
  15. K1561824596379
    Cupcake Dec 2, 2019
    K1561824596379 , Dec 2, 2019 :
    Can we set new password for the app lock not the home screen password. Hope it will fix in the next update[e]1f604[/e] # one plus[e]2764[/e]️
    #75
  16. L1529399944990
    Eclair Dec 2, 2019
    L1529399944990 , via OnePlus 6 , Dec 2, 2019 :
    after updating the latest beta on 30 nov the screen started shimmering or fluckers. and screen lock once put it again locks only fingerprint works and all my app PWD has been removed and won't accept password
    please fix the bug.
    #76
  17. I1555022596541
    Cupcake Dec 8, 2019 at 1:18 PM
    I1555022596541 , Dec 8, 2019 at 1:18 PM :
    Hello, I have version A6003_22_191120 and have two small(?) issues:
    - auto screen brightness became too low when in dark ambients, wasn't like that before updating to Android 10
    - during incoming call, if it's minimized and apearing in the notification bar, draging down and touching the green "answer" icon doesn't answer the call. Can't find a way to answer those calls at all!
    Anyone with same issues?
    #77
  18. Marbona
    Donut Dec 8, 2019 at 2:43 PM
    Marbona , via OnePlus 6T , Dec 8, 2019 at 2:43 PM :
    After updating to Android 10.0.1 from pie 9.0.17 , the haptic feedback from the fingerprint sensor is gone. I reverted back to pie, did a full wipe but the feature is still missing. Please, address this issue on next update.
    #78
  19. yiybuhijik
    Cupcake Dec 8, 2019 at 3:13 PM
    #79
  20. P1550138069589
    Donut Dec 8, 2019 at 10:08 PM
    #80
