9
[Submitted] Known Issues for OnePlus 7 Pro
  1. LOCKDOWN117
    Ice Cream Sandwich Aug 14, 2019
    LOCKDOWN117 , Aug 14, 2019 :
    i have edited RAW samples of 48 and they are great! you can get them online just search for honor 20 sample and download 48mp raw
  2. Swejuggalo
    KitKat Aug 14, 2019
    Swejuggalo , Aug 14, 2019 :
    Do that use the same sensor? I guess they can make a rather nice 48MP version then. Despite being called "approximation".
    Here is the partly negative review of the sensor that calls it approximated 48MP.
    https://www.androidpit.com/48-mp-or-not-look-at-sony-new-camera-sensor
  3. LOCKDOWN117
  4. Swejuggalo
    KitKat Aug 14, 2019
    Can't keep up and memorize every single phone using that sensor. Too much to handle at work already [e]1f609[/e]
    Haven't seen much samples of devices using the same sensor. Just that comment about the sensor that made me doubt a truly good 48MP mode.
  5. LOCKDOWN117
    trust me im into phone photography and the samples that i have downloaded are very good
    https://www.photographyblog.com/reviews/honor_view20_review/sample_images
    i have edited the Raw samples and they turned out better then my 12mp raw
  6. G_Chris_Lambert_wbmY
    Eclair Aug 14, 2019
  7. aswadref
    Cupcake Aug 15, 2019
    aswadref , Aug 15, 2019 :
    I am having the same issue with the speaker phone when I make a call other side barely hears anything the voice quality is very very bad
  8. Swejuggalo
    KitKat Aug 15, 2019
  9. vjgeorge87
    Froyo Aug 15, 2019
    vjgeorge87 , Aug 15, 2019 :
    Did you try initiallising "Screen Mirroring" through Sony tv and simultaneously with your OnePlus phone?
  10. Neel11
    Neel11 , Aug 15, 2019 :
    Yes! Infact, I even tried by forgetting and then reconnecting .
    It goes into screen mirroring but after that my 7 Pro acts as if there was not wireless device to be cast upon
  11. vjgeorge87
    Froyo Aug 15, 2019
    Neel11
    It goes into screen mirroring but after that my 7 Pro acts as if there was not wireless device to be cast upon​
    Make sure WiFi Direct is switched "on" from both devices.
    While initialising from tv, go to Settings -> Bluetooth & device connection -> Connection preferences -> Cast -> "Check" enable wireless device by touching the 3 dots on top right and by this your phone should search for available devices on the SAME WiFi network.
    Select your tv and it should connect. Sample screenshot from my device.
  12. bjsu562
    Donut Aug 16, 2019
    P4p4y4 likes this.
  13. P4p4y4
    Cupcake Aug 16, 2019
    bjsu562 likes this.
  14. Y1565967785436
    Cupcake Aug 17, 2019
  15. staygold1gr
    Froyo Aug 17, 2019
  16. Gunjan Ft Shady
    Froyo Aug 18, 2019
    Gunjan Ft Shady , Aug 18, 2019 :
    Hi Team,
    This update had rectified the App strutter, scrolling and system lag....
    But the issues have returned.... I think the issue is with the apps who are unable to keep up with 90Hz.... But if this issue is with the software so kindly rectify it...
    I hope the next update rectifies it for the good...
  17. Shimon_Asulin
    Eclair Aug 18, 2019
    Shimon_Asulin , Aug 18, 2019 :
    Low Audio Quality from the mic when the phone is on speakers during the call(other people receives the broken voice).
  18. RelaxOP
    Eclair Aug 18, 2019
    RelaxOP , Aug 18, 2019 :
    Microphone quality is very bad when on speakerphone only, I think the microphone dedicated for speakerphone sound is not even activated at all and the directional microphone that's used for normal calls is the only one that's working, because when I'm making a voice memo or talking to Google assistant across the room, it works very well and it understands me, but when I'm talking with someone and move just a couple inches away they can't hear me anymore. Please fix this, I'm using speakerphone and this is unbearable
    #38
  19. scrin378
    Eclair Aug 19, 2019
    scrin378 , Aug 19, 2019 :
    My phone randomly shuts down when in stand by mode...
    it happens on all oos from 9.5.7 - 9.5.11.
    dont know is it software or hardware related ;(
    its really annoying.
    #39
  20. Jediknight
    Gingerbread Aug 19, 2019
    Jediknight , Aug 19, 2019 :
    Seems like two updates already since the shaky video on Oneplus 7 pro but still it is still not fixed. i don't know how many people are aware of this problem?
    here are my shaky sample videos (EIS not working in 30 fps):
    https://drive.google.com/file/d/1-U7cSHWTVdbOMlu3YtkueKrKWz-RFvgi/view
    https://drive.google.com/file/d/1-uP6JpQCvAe8blI17iwAGsife-Zr0vKb/view
    https://drive.google.com/file/d/1-xgkfOWvN_8-GEONs1uDvD1uYq_x_DKU/view (shaky the becomes stabilized)
    it happens not all the time but when I need to take a video, I record shaky videos instead. Tried recovery mode clear cache and still not working.
    #40
