9
[Submitted] Known Issues for OnePlus 7 Pro
  1. S1569227988063
    Cupcake Sep 23, 2019
    S1569227988063 , Sep 23, 2019 :
    Sometime a bright bluish glowing dot appears on my screen, at a point top right to the center of the screen. After i restart the phone, it disappears.
  2. A1566660222123
  3. George Psaltas
  4. G1569258149743
    G1569258149743 , Sep 23, 2019 :
    My phone is muted by mistake. Now I am not able to increase volume of ringtone. Can anybody help me?
  5. kartik198
    Eclair Sep 23, 2019
    kartik198 , Sep 23, 2019 :
    there is huge battery drain both active and ideal on Android q stable for 7 pro as compared to pie
    JMCCLENNY10 and insomniachou like this.
  6. giannishalde
    Cupcake Sep 24, 2019
    giannishalde , Sep 24, 2019 :
    The " hidden choice" navigation buttons in dark mode is too transparent when you use it for the first time after you turn on your phone
    You have to hide and show it again in order to fix that issue.
  7. Lahirurd
    Froyo Sep 24, 2019
    Lahirurd , Sep 24, 2019 :
    I'm on the latest stable android 10 build.
    I did a clean wipe after the update.
    There's an issue with "Recent apps gestures" I'm using the "bottom" gestures. Sometimes when I do this, I get the vibration but it doesn't show me the apps, instead it gets redirected to the app which I'm using. It happens once in a while.
    I had the equaliser for my Bluetooth audio when I was in beta 1 & 2. But with this stable build, no equaliser at all...
    Can you guys add that?
    Thanks a lot!
    Andrewkir likes this.
  8. A1569332267053
    A1569332267053 , Sep 24, 2019 :
    Android 10 stable not work bluetooth audio. My car is Mazda Cx7 and with android 9 connect perfect.
    i have install android 10 with factory reset.
    if toggle phone call, in bluetooth option it connected...
    Help you, thank you
  9. JavieRozen
    Donut Sep 24, 2019
    JavieRozen , Sep 24, 2019 :
    Hi there.. The only issue I think for now is the horizon light.. When a new notification pops the screen does not turn on and when using the SwiftKey keyboard,there's a little gap between the space key and the bottom of the screen,so sometimes when tapin on that space the app in use close it self
  10. fembajador1
    Cupcake Sep 26, 2019
    fembajador1 , Sep 26, 2019 :
    Hi, I update my oneplus 7 pro to android 10 and I have a problem. All the sound tones (call, message, notification...) have disappeared. I have only my own tones (music who is in my phone).What can I do???? Thanks to help me.
  11. simonerolando98
    simonerolando98 , Sep 26, 2019 :
    I found another small bug. OnePlus Launcher on OxygenOS 10.0.GM21BA is able to find apps which shouldn't be found by a launcher, such as Google Play Services for AR, Carrier Services and Poweramp Pro Unlocker. I had to put them into the secret space, because they bother me [e]1f602[/e]
    Lahirurd and insomniachou like this.
  12. insomniachou
    Honeycomb Sep 27, 2019
    kartik198 likes this.
  13. JMCCLENNY10
    Donut Sep 27, 2019
  14. Njinsa
    Eclair Sep 27, 2019
    Njinsa , via OnePlus 7 Pro , Sep 27, 2019 :
    I too have a issue with the earpiece, sound is distorted and sounds like electrical interference.
    it's annoying and I can't get rid off it..
  15. NeoElettoTheOne
    Froyo Sep 29, 2019
    NeoElettoTheOne , Sep 29, 2019 :
    After Android 10 stable update,I'm facing those issues:
    - Bluetooth connect to my Mazda 3 only for calls,not for multimedia.
    - My alarm app "Timely",don't turn the screen on anymore,if an alarm is ringing. I have to unlock the phone,tap the notification and turn the alarm off.
    Insane.
    - The brightness of the display,goes so low in dark rooms,that the oled colours are completely wrong.
  16. G_Jan_Louise_Santiago_iN
    Eclair Sep 29, 2019
    G_Jan_Louise_Santiago_iN , Sep 29, 2019 :
    Facebook messenger chatheads are flickering when you are normally using the phone. IDK what triggers it. It wasn't like this on OOS 9.5.11. I'm currently on OOS 10.0.0
  17. laikexpert
    Froyo Sep 29, 2019
    laikexpert , Sep 29, 2019 :
    I'm facing those issue:
    Different sounds
    for system and sms notifications
    dont work.
    P.S.
    Issues with notification sounds. I'm trying to have different sounds for system and sms notifications but for some reason this dont work.
    In Android 10 Beta versions,
    everything worked fine.
