17
[Submitted] Known Issues for OnePlus 7 Pro
  1. rcaldejr
    Eclair Jan 26, 2021
    rcaldejr , via OnePlus 7 Pro , Jan 26, 2021 :
    The Android 11 Beta 1 for OnePlus 7 Pro does not allow me to answer phone calls.
    List of steps tried:
    - Clear Cache of phone app. (Tried with Google Phone app as well)
    - Clear storage of phone app. (Tried with Google Phone app as well)
    - Attempted to, while receiving a call, lock and unlock the device as a workaround, but with no luck.
    - Cleared system cache in recovery.
    - Finally a full factory reset of my device.
    Phone calls can be made outbound from the device. I only cannot answer an incoming call.
    JoeDat and SgipMaster like this.
  2. Dale_Hennessey
    Cupcake Jan 28, 2021
    Dale_Hennessey , Jan 28, 2021 :
    Possible issue: WIFI on Android 11 Beta 1, OnePlus 7 Pro.
    I have three WIFI networks at home: 1x 2.4GHZ and 2x 5GHZ.
    My phone connects to 2.4GHZ just fine, but for both of the 5GHZ networks I can connect successfully but get "No Intenet." This is not correct as I have multiple other devices that can connect to both 5GHZ networks and properly get internet. I have tried completely forgetting the networks and reconnecting and the problems continues.
    Please let me know if I can run diagnostics or collect logs for you!
    Work-around for now is to just use the 2.4GHZ network.
  3. mtalexan
    Cupcake Jan 30, 2021
    mtalexan , via OnePlus 7 Pro , Jan 30, 2021 :
    Reported these separately also, but:
    1. Using any SMS app other than Oxygen Messages doesn't notify the app when a message is received, causing a 10+ minute delay until a poll event from the app checks for unreported new messages.
    2. Lock screen with fingerprint can be bypassed by opening the camera from the lock screen shortcut and then using the home button/gesture to reach the Launcher home page without authentication.
    3. Changing the default Launcher is ignored and the Oxygen Launcher continues to be used until an undefined number of reboots and re-attempts after upgrade. This includes the pre-existing Launcher in use with OxygenOS 10 being ignored and the Oxygen Launcher being used rather than the configured Default Launcher in the system settings
  4. caillean_Byrne , via OnePlus 7 Pro , Jan 30, 2021 :
    These are really strange issues I've never encountered.
  5. rcaldejr
    Eclair Feb 6, 2021
    rcaldejr , via OnePlus 7 Pro , Feb 6, 2021 :
    Have just upgraded to OB2, and the exact same issue is still present.
    Same workarounds have been done as well.
    JoeDat likes this.
  6. Marius.badana
    Cupcake Feb 7, 2021
    Marius.badana , Feb 7, 2021 :
    Device: Oneplus 7 Pro OxygenOS Beta2 bug:
    Description: When swiping down before unlocking the device, the screen will freeze (an overlay will be displayed over it)
    Prerequisites:
    1. Make sure face unlock is enabled
    2. Enable swipe down to access Notifications & Quick Settings from the Launcher settings menu
    Steps to reproduce:
    1. Whith the screen off, double tap the screen (if not enabled press the power button)
    2. Swipe down so the face unlock will open
    3. Login using your face
    4. Collapse (using swipe-up gesture) the notification bar
    Expected result:
    The screen is enabled and I can use any gestures on the launcher
    Actual result:
    The screen is disabled (has an overlay drawn over it).
    What happened:
    When the swipe down gesture is made from the lockscreen, it also triggers the Notification & Quick settings bar to be expanded. After logging in, the overlay is not removed and after collapsing the notifications & quick settings, the user cannot use the screen until another unlock.
  7. zed sharma
    Donut Feb 25, 2021
    zed sharma , Feb 25, 2021 :
    Still after update it's buggy Idk what they are doing this seriously this not done
  8. sai143ganesh
    Cupcake Feb 25, 2021
  9. DJSubterrain
    Ice Cream Sandwich Mar 1, 2021
    DJSubterrain , via OnePlus 7 Pro , Mar 1, 2021 :
    Just updated to the Open Beta 3 of Android 11, assistive lighting for face unlock still does not seem to be working although the option is enabled.
    Using Nova Launcher and the screen does not change to white as in previous versions of Oxygen OS
  10. piexv
    Eclair Mar 14, 2021
    piexv , Mar 14, 2021 :
    MMS problem,
    sending reception impossible, you must activate and deactivate airplane mode to send and receive MMS.
    APN ok.
    7TPro McLaren Beta 3 - Android 11.
    Dolby atmos add EQ !!!!!!! In France
  11. mcpro24fps
    Cupcake Mar 19, 2021
    mcpro24fps , Mar 19, 2021 :
    On OnePlus 7T not available AUX Cameras (2,3,4,5) for 3rd-party apps. Only 0(main) and 1 (selfie) is available. On 10 android this cameras could be activated with crutches, but on 11 android this cameras are "Hidden".
    Not available 24 and 25 fps.
    That problems is on all OnePlus devices. What universe does the manufacturer live in?
    In attachment file with all cameras description.
  12. sai143ganesh
    Cupcake Mar 20, 2021
  13. dawnofsoap
    Cupcake Mar 21, 2021
    dawnofsoap , Mar 21, 2021 :
    Device: Oneplus 7 Pro OxygenOS Beta 4 (and 3 as well)
    Description: All calls route through bottom speaker when on "phone" mode.
    Prerequisites:
    1. None
    Steps to reproduce:
    1. Receive or make a call
    2. answer and listen to the other end of the line speak. When speaking you will notice all call audio is routed to the bottom speaker.
    3. When selecting speaker phone, it gets much louder.
    4. When reverting back to earpeace mode, it routes back to the bottom speaker
    Expected result:
    Call audio routed through earpiece
    ccampos784 likes this.
  14. franknozly
    Eclair Mar 23, 2021
    franknozly , Mar 23, 2021 :
    I reported the same issue on open beta 3 and submitted logs, and here they are releasing the next stable build which has the exact same problem, nothing fixed. Now everyone's 5GHz wifi is broken and there's no way to revert to Android 10 without doing a full wipe.
    Don't know what's the point of submitting these reports, logs, and bugs. Nothing gets fixed and they release broken builds anyways.
    BugsBugsEverywhere likes this.
  15. senpoos
    Cupcake Mar 26, 2021
    senpoos , Mar 26, 2021 :
    After the stable update of Android 11 in OnePlus 7 Pro - Sensor - Step Detector is not working and so apps like Google fit don't work
  16. canucks4life
    Gingerbread Mar 27, 2021
  17. ccampos784
    Cupcake Mar 27, 2021
    ccampos784 , Mar 27, 2021 :
    I'm having the same issue as well on stable Android 11. It looks like this is caused by having my smartwatch (Galaxy Watch) connected to the phone. If I turn off phone calls in Bluetooth settings for the watch, then audio is routed correctly to the earpiece.
  18. BlitzCr1tz
    Cupcake Mar 28, 2021
    BlitzCr1tz , Mar 28, 2021 :
    Device: Oneplus 7 Pro OxygenOS 11.GM21AA
    Description: Randomly disconnects on wifi.
    Prerequisites:
    1. Frenshly turned on from standby mode or just turned on the phone.
    Steps to reproduce:
    1. Connect to wifi.
    Actual behavior:
    Disconnected wifi. Need to manually connect again. Sometime it will drop again and repeat the cycle.
    Expected result:
    Does not auto disconnect to wifi.
    franknozly likes this.
  19. Berni_82
    Cupcake Mar 29, 2021
    Berni_82 , Mar 29, 2021 :
    Hola, la versión de oxígen 11 GM21BA da errores constantes de IU con cierres del sistema y el consumo de batería es desorbitado
  20. 1PLUS1=TWO
    Donut Mar 31, 2021
    1PLUS1=TWO , Mar 31, 2021 :
    Device: Oneplus 7 Pro, OxygenOS 11.GM21BA
    Slow(er) performance
    Battery drain
    Lagging issues
