19
[Submitted] Known Issues for OnePlus 7 Pro
  1. scrin378
    Eclair Apr 3, 2021
    franknozly likes this.
  2. mlulic
    Ice Cream Sandwich Apr 6, 2021
    KniteStarz likes this.
  3. mlulic
    mlulic , Apr 6, 2021 :
    EU version has no EQ. That's why mine is flashed global. :D
  4. Q1609292087628
    Cupcake Apr 6, 2021
  5. Coliofsandy
    Cupcake Apr 7, 2021
    Coliofsandy , Apr 7, 2021 :
    Hi! I leave my problems with the last update.
    The WiFi still not working correctly at the last beta update. And sometimes a error of forced closure of an app apears, but I can't see wich one, because it closes too fast.
  6. atenaa
    KitKat Apr 7, 2021
    atenaa , Apr 7, 2021 :
    After the update to android 11 I'm having problems with the SMS app. The app crashes when sending new SMS.
    I open the SMS app and click in new message. Click in "To: " bar to search contacts. After entering the second letter the app crashes.
    But if I reply to an existing message, the issue doesn't occur.
  7. G_Terry_Dougherty_LGsa
    Eclair Apr 19, 2021
    G_Terry_Dougherty_LGsa , Apr 19, 2021 :
    What about all of the people who are having the phone only answer in speaker mode. And cannot switch to earpiece. Please acknowledge and fix this... I need to take calls in private not where everyone in the office hears!
    Tperkins and elizabethjohnsen87 like this.
  8. G_Terry_Dougherty_LGsa , via OnePlus 7 Pro , Apr 19, 2021 :
    Same problem!!!
  9. Y1619157906052
    Cupcake Apr 23, 2021
    Y1619157906052 , Apr 23, 2021 :
    When using 90hz on a OnePlus 7 Pro, then lock the phone, the screen does not respond when attempting to unlock. If it does respond, the fingerprint sensor does not appear, and the screen zooms/crops into the numpad for the pin, cropping out the numbers on the right side of the screen. Only fix is to restart the phone, and immediately change the refresh rate back to 60hz before unlocking the phone.
    Build Number: Oxygen OS 11.GM21AA
    KDKid likes this.
  10. Palal
    Donut Apr 25, 2021
    Palal , Apr 25, 2021 :
    My capacitative back button stops working after opening the settings menu on the phone. A restart fixes things.
    Latest oxygen 11 update
  11. KDKid
    Eclair Apr 25, 2021
    KDKid , Apr 25, 2021 :
    Thanks for the advice on the 90-60hz thing. Quick solve for the display issue, but the battery complaints and the overheating, voice, etc, etc has me genuinely regretting the update. I saw "Android 11" and thought "Cool! What's the worst that could happen?"
  12. A1619394511159
    Cupcake Apr 26, 2021
    A1619394511159 , Apr 26, 2021 :
    Mine does the same thing even on 60 hz.
    the touchscreen still works, but the icons don't line up with where they normally are which is where you need to touch.
    logging in is possible though tedious and frustrating.
  13. L1605726714366
  14. G1576356443022
    Cupcake Apr 27, 2021
    G1576356443022 , Apr 27, 2021 :
    The Wi-Fi not working is such a horrible bug. Please One Plus, respond to our troubles and fix this
  15. U1562784784899
    Cupcake Apr 28, 2021
    U1562784784899 , Apr 28, 2021 :
    I have this exact same problem.
  16. G_PavorNocturnus_PKNw
    G_PavorNocturnus_PKNw , Apr 28, 2021 :
    I have issues with chrome. It freezes so often after update and also i can't use my rear camera on chrome and also on other browsers also. Is there any solution for it? I did delete chrome and reinstall it completely but it is the same
  17. rweiljr
    Cupcake Apr 29, 2021
    rweiljr , Apr 29, 2021 :
    After update, these issues - phone answers in speaker mode - SMS notification tone does not work - vehicle android auto will not recognize that phone is plugged in, even though the phone is charging (and in the correct usb port) - adaptive brightness doesn't work well - lags while trying to start a new SMS
  18. Tperkins
    Donut Apr 29, 2021
    Tperkins , Apr 29, 2021 :
    Same issue here for phone answering in speaker mode. With so many complaints, why does not OnePlus fix this issue?
  19. R1545021630140
    Cupcake Apr 30, 2021
    R1545021630140 , via OnePlus 7 Pro , Apr 30, 2021 :
    The issue I'm having with my op 7 Pro is that whenever I leave the radius of my wifi network and return, my phone flat-out refuses to reestablish VO Wi-Fi unless I restart my phone, I can use the internet but no calls or texts. I live in a rural area with no signal in my home so VO Wi-Fi is my only option when at home.
