17
[Submitted] Known Issues for OnePlus 7 Pro
  1. Deactivated User
    Oct 17, 2019
    #41
    Sakib4 likes this.
  2. Stelios_Batz , via OnePlus 7 Pro Mirror Gray , Oct 17, 2019 :
    I received Android 10.0.1 via OTA and I noticed that in Greek language the letter in the red rectangular appears as a letter in the blue rectangular. even if I copy the letter in the red rectangular when I paste it appears us the letter in the blue rectangular
    #42
  3. Sunilsk
    Cupcake Oct 18, 2019
    Sunilsk , Oct 18, 2019 :
    Bluetooth Media isn't working in Android 10. Unable to play music when phone is connected to car's bluetooth.
    #43
  4. #44
    kartik198 likes this.
  5. daninantro
    Ice Cream Sandwich Oct 18, 2019
    daninantro , Oct 18, 2019 :
    The battery on oos 10.0.1 is draining quickly compared to 10.0 . I have the same apps installed, nothing new.
    #45
  6. Sampad Roy
    Froyo Oct 18, 2019
    Sampad Roy , Oct 18, 2019 :
    Proximity Sensor Issue still persists in 10.0.1.
    The screen continuously keeps waking up during calls.
    #46
  7. F_Castro_EICP
    Gingerbread Oct 19, 2019
    #47
    D1566071783845 and Sampad Roy like this.
  8. PranavRaj96
    Cupcake Oct 19, 2019
    PranavRaj96 , via OnePlus 7 , Oct 19, 2019 :
    Faceing the Same Navigation Gesture issues in Oneplus 7 Android 10 update
    #48
  9. Vamsi Saladi
    Vamsi Saladi , Oct 19, 2019 :
    when getting a call and you take the phone out of your pocket it takes not of time brighten the screen. The screen is too dull to see who is calling or what is on the screen. - proximity sensor issue,
    There is also a lot of accidental touches when taking a call - call going to hold, mute etc .. ..
    In ambient display there is "pick up your phone to show" I enabled it, but phone is not properly recognizing flat vertical pick up or any other small motion pick ups. I have to tap to use finger print. This is an extra step which is unnecessary. I have to pick up in a curve or slight jerk some other direction to wake up display. I upgraded from one plus 6t(which i am still using). 6T is still better responding and functioning then the latest and more premium 7 pro.
    #49
  10. Vamsi Saladi
    #50
  11. #51
  12. supertrackster
    supertrackster , Oct 19, 2019 :
    I have noticed that often the screen does not turn off by itself after the 30 seconds set. Restarting the phone resolves the problem only for a while, then obviously the fault starts again
    #52
    Sakib4 likes this.
  13. Daniel Ramos Mendez
    Daniel Ramos Mendez , Oct 19, 2019 :
    Things I experience after upgrading (One Plus 7 Pro):
    - Unblocking is slower.
    - Gcam photos display "Processing HDR+" and then the image disappears.
    Also, I've always had this annoying problem when trying to listen to WhatsApp audios, the audio switches as if I had the phone in my ear... Gosh.
    #53
  14. Q1562426614574
    Cupcake Oct 20, 2019
    Q1562426614574 , Oct 20, 2019 :
    After the os 10 update The device is lagging slight in poformance and the finger print screen lock is working very slow
    #54
    Sampad Roy and kartik198 like this.
  15. cytrusleavs.
    Eclair Oct 20, 2019
    #55
  16. Gmeldridge
    Froyo Oct 21, 2019
    Gmeldridge , Oct 21, 2019 :
    I am also experiencing screen flicker when plugged in and screen going black. It doesn't matter what app I am using. I went back to 9.5.13 and do not have the issue. I did a clean install and wiped data for 10.0.1 and problem still exists. Also significant battery drain OOS 10.0.1
    #56
  17. Xentar712
    Cupcake Oct 21, 2019
    Xentar712 , Oct 21, 2019 :
    When switching to a guest or another user account, the navigation bar is persistent across ALL apps. This is a huge problem and makes some apps unusable. I have gesture navigation enabled on the admin account but all the other accounts are stuck with three buttons and there's no way to disable them. Any idea how to fix or is this a bug? This was not an issue with 9.5.13
    #57
  18. atenaa
    KitKat Oct 21, 2019
    atenaa , Oct 21, 2019 :
    Issue with 10.0.1
    When in a call the screen randomly turns on and my face unintentionally presses the loud speaker button. The sound blasts into my ear and it's deafening. It's really annoying!
    This problem happend with Android 9 too.
    #58
    H1523966501604 likes this.
  19. istmmi
    Cupcake Oct 22, 2019
    istmmi , via OnePlus 7 Pro , Oct 22, 2019 :
    Hello,
    after upgrading to the new Oxygen OS 10.0.1 (Build number says 10.0.1.GM21BA), my battery was drained under 6 hours. charged it and waited for a couple of days since I know that the brand new OS is optimizing stuff for a long time. It's been a few days already, but I still wake up with a dead phone. I wish I hadn't upgraded. The last charge lasted 19 hours. I feel the phone smoother, thanks, but I wish I had the battery time back, because THAT is what makes the difference between OnePlus and Samsung/Apple. Please help me downgrade.
    #59
  20. Shoeb_patel
    Eclair Oct 22, 2019
    Shoeb_patel , Oct 22, 2019 :
    Two major issues that are so annoying that I have to keep a separate phone for calling.
    1. Proximity Sensor:
    • Screen is still awake whilst on call, just keeps pressing random buttons drags down notification panel, keeps toggling buttons in quick settings panel.
    • Big time glitchy "raise to answer" & "raise to switch" features.
    • The screen goes black while listening to voice notes on WhatsApp and plays through earpiece even if the phone is on a flat surface.
    2. Poor Mic
    • The other party can't hear me properly on every call.
    #60
    R1558910837372 and Sampad Roy like this.
