19
[Submitted] Known Issues for OnePlus 7 Pro
  1. H1558557655860
    Cupcake Dec 10, 2019
    H1558557655860 , Dec 10, 2019 :
    My issues on 10.0.2:
    1. ghost touches are back, i had them on early v9, then they were fixed and are back. Locking and unlocking the phone solves them for me. Happens like two times per day or so.
    2. brightness is always reset to slightly above minimum when i lock and unlock the phone. The Auto control was working fine in v9. Now its not usable at all, too dim always. Workaround: Lux.
    3. Horizon light never worked for me, no matter the Android version.
    Sent this to OnePlus support mail, they promised to send it to their development team and told me i can post here too.
    Then there some small things, like some notifications have hardcoded black text, so when i use Dark mode, the text of the notification is unreadable.
    It seems to me the phone now slows down after few weeks without reboot, which was not happening on v9.
    What started working is equalizer in XiiaLive, previously on v9, there was some kind of error about sound fx modules, probably was related to the way how Atmos is implemented.
    Still the best phone i ever had, but small issues like these make the experience inconsistent over time.
  2. Qmaula
    Eclair Dec 10, 2019
    Qmaula , via OnePlus 7 Pro , Dec 10, 2019 :
    3g4g connectivity drop when opening an application that needs GPS. Happening in 10.01 and 10.0.2. Other users confirms the same problem. All them have in common a work profile also installed.
  3. Deactivated User
    Dec 11, 2019
    Sampad Roy likes this.
  4. budburr
    Cupcake Dec 12, 2019
    budburr , via OnePlus 7 Pro , Dec 12, 2019 :
    I have inability to select and play music through bluetooth in my 2013 bmw 3 series with the cic infotainment system running Oxygen 10 open beta.
    Apollom4m likes this.
  5. N1559985529026
    Cupcake Dec 13, 2019
    N1559985529026 , Dec 13, 2019 :
    Both 10.0.2 and 10.0.1 have the same problem. After the mobile phone is connected to the Bluetooth headset, then turned off the Bluetooth headset , and then the wired headset is inserted, and then the mobile phone cannot recognize the wired headset.Wired headsets can be recognized correctly only after the phone restarts
    David Turney likes this.
  6. J1558857502742
    Cupcake Dec 14, 2019
    J1558857502742 , via OnePlus 7 Pro , Dec 14, 2019 :
    So, I notice that some buttons and numbers are looking very 'soft' on OP7 pro. I'm pretty sure its a bug on onephone as my xiaomi doesn't suffer from it. Its a NYTimes app if you guys wanna check it out yourself.
  7. abhay@99
    Cupcake Dec 17, 2019
    abhay@99 , via OnePlus 7 Pro , Dec 17, 2019 :
    i have also that problem
  8. F_Andrew_Lydon_RdsG
    Cupcake Dec 19, 2019
  9. Sampad Roy
    Froyo Dec 19, 2019
    Sampad Roy , Dec 19, 2019 :
    Same.. and this still hasn't been solved.
  10. bipuwam
    Gingerbread Dec 20, 2019
  11. bipuwam
    Gingerbread Dec 21, 2019
    bipuwam , Dec 21, 2019 :
    I'm facing ghost touch every time I've to restart my phone several time.
  12. Gertjan@
    Honeycomb Dec 23, 2019
    Gertjan@ , via OnePlus 7 Pro , Dec 23, 2019 :
    Screen freezes randomly when using app or browser, and after freezing the set wallpaper is transformed into the standard live wallpaper of Oneplus!
    wolvorine1994 likes this.
  13. Inder Singh 0105
    Cupcake Dec 23, 2019
  14. V1573549100530
    Cupcake Dec 24, 2019
    V1573549100530 , Dec 24, 2019 :
    I use hotspot a lot as there is no WIFI where I live, Following the update to Oxygen I've found that Turning on Hotspot disables 4G rendering it useless... can't see this as a known issue so don't know if I should report this here or elsewhere.
  15. R_sheth
    Cupcake Dec 25, 2019
    R_sheth , Dec 25, 2019 :
    I have OnePlus 7 pro and it fails to give me result when I connect it to the apple airpods.
    while driving the other person on a call, can not hear me at all and the only sound is of surrounding noise on a extreme level.
    I suggest you to add noise cancellation feature for such kind of issues.
  16. ssdclarke
    Cupcake Dec 27, 2019
    ssdclarke , via OnePlus 7 Pro , Dec 27, 2019 :
    I have two 1+7pros and they are doing the same thing. Saskatchewan, Canada.
  17. SAI123sai
  18. SAI123sai
  19. O1577607610497
    Cupcake Dec 29, 2019
    G1580215787615 likes this.
  20. Sonuraj40
    Sonuraj40 , Dec 29, 2019 :
    hi anyone please let me know the solution , of my One plus 7pro when I am trying to share Image's or video to someone in what's app doesn't work at all , what's app completely goes freeze .
