19
[Submitted] Known Issues for OnePlus 7
  1. Arluy
    Donut Jun 8, 2020
    Arluy , via OnePlus 7 , Jun 8, 2020 :
    thank you. I will try this right now
  2. ady_agar
    Froyo Jun 18, 2020
    ady_agar , via OnePlus 7 , Jun 18, 2020 :
    1. Unreal heating up while gaming in medium settings. Hot enough to hinder touching the screen or holding it without a case.
    2. Same issue while charging as well.
  3. wolf4477
    Froyo Jun 19, 2020
    wolf4477 , via OnePlus 7 , Jun 19, 2020 :
    It doesnt work, its a "proximity" sensor bug, pocket mode when ambient is dark "thinks" phone is into pocket so blocks every touch responsivness
  4. Rubikulous
    Cupcake Jun 19, 2020
    Rubikulous , Jun 19, 2020 :
    Same here. All blurry images in portrait mode.
  5. Bakgrund
    Froyo Jun 27, 2020
    Bakgrund , Jun 27, 2020 :
    Have Oneplus even acknowledged the double tap to wake/ambient display issue?
    If I know them right it won't ever be fixed.
    Lucky_19 likes this.
  6. K1593288195686
    Cupcake Jun 29, 2020
    K1593288195686 , Jun 29, 2020 :
    Bonjour à tous,
    Me concernant le mode portrait ne fonctionne plus correctement depuis la dernière mise à jour. Le premier plan est flou et le second flou ou nette, ça dépend. Le problème apparaît surtout lorsque le sujet pris en photo est un visage.
  7. 0177382345
    Eclair Jun 29, 2020
    ady_agar likes this.
  8. rpkkiran , via OnePlus 7 Pro Mirror Gray , Jun 30, 2020 :
    Hey guys, I'm facing random display issues. Screen goes red with the colors being way off and returns to normal randomly. Sometimes it becomes green and returns normal. Sent for service and they told that they did not find any hardware issue with the phone and also completely clean flashed my phone with the latest software. Has anyone else experienced this?
  9. C1577375614610
    Cupcake Jul 7, 2020
    C1577375614610 , Jul 7, 2020 :
    I have problem with screen unlock it works very slow
    and the other issue is with contact list
    it's getting multiple day by day
    I was having only 760 contacts now it's 78000 contacts
    plz fix it as soon as possible
  10. Arluy
    Donut Jul 9, 2020
  11. Abhijit Talathi
    Eclair Jul 15, 2020
    Abhijit Talathi , via OnePlus 7 , Jul 15, 2020 :
    Also unable to dial to default contact automatically
    100 times suggested to highlight default contact's
  12. ItsFarukh
    Froyo Jul 16, 2020
  13. ItsFarukh
    Froyo Jul 17, 2020
    ItsFarukh , via OnePlus 7 , Jul 17, 2020 :
    Frame skip
    Sometimes when I move left/right in any game I play like madden, UFC, codm, pubgm or any other app My touch doesn't register till 3-4 seconds later then it skips to end frame like shown in slow motion part of this video
    I kept swiping right on screen to turn my character but it didn't turn till 3-4 seconds later and it didn't show my character turning like it normally does but just skipped to end frame of my Character already turned. It's ONLY been happening since 10.3.3 update but now in open beta 16 it doesn't happen that much, just 10-15% of time but problem is still not completely gone.
  14. F1595034466061
    Cupcake Jul 18, 2020
    F1595034466061 , Jul 18, 2020 :
    After I move the phone from my ear in a call in reverts back to the home screen and I either have to find the ongoing call by looking through the pull down menu or going to my previously used apps button (the bottom square next to the home button) so if I'm in a call where I have to make a number selection or before I can hang up the call I have to do that it's pretty frustrating and I'm wondering if this is happening to someone else.
    Also my Pandora keeps freezing and I have to keep closing it and re opening it every so often I've tried uninstalling and reinstalling but it's a persistent problem.
    To be honest I really don't like this phone I can't wait to get rid of it. There are a million problems I agree with what a lot of you say especially
    Battery
    Navigation issues
    Connection
    Sometimes I have to just restart my phone because it puts itself into an airplane type mode and I can't make calls or do anything but my airplane mode isn't on so luckily restarting it Helps but I'm worried one time it won't.
  15. Bhanusolanki
    Cupcake Jul 25, 2020
    SPYROPOULOS likes this.
  16. M1565451550129
    M1565451550129 , Jul 25, 2020 :
    my one plus 7 device have so many issues like lagging,hanging when I'm using what's app and all the apps, all apps are not working perfectly and also the device was heating a lot.....
    ~heating problem
    ~lot of bugs
    ~apps not working
    ~lags
    ~hanging
    ~worst Gaming performance
    ~worst signal strength
  17. SPYROPOULOS
    Cupcake Jul 27, 2020
    SPYROPOULOS , Jul 27, 2020 :
    oneplus 7t pro
    i have some problems with camera. the quality is low after the update 10.0.9
  18. puwasuru
    Cupcake Jul 29, 2020
    puwasuru , Jul 29, 2020 :
    I have the same issue. Now its been two months. No fix yet.
  19. Allan Jensen
    Cupcake Aug 2, 2020
    Allan Jensen , Aug 2, 2020 :
    OnePlus 7T, OxygenOS 10.0.11:
    The phone locks spontaneously; sometimes very rarely, sometimes I unlock and it locks itself within one second, and keeps doing so, so my phone is nearly unusable on occasion.
    It also happens even when mounted in the car holder, using Google Maps for navigation.
    It seems to be a proximity sensor issue as it will lock and then display the fingerprint sensor.
    This wasn't an issue with the previous release.
    I sincerely hope this issue is fixed in the next OxygenOS release, as I will otherwise have no other option than to RMA it.
  20. ItsFarukh
    Froyo Aug 4, 2020
    ItsFarukh , via OnePlus 7 , Aug 4, 2020 :
    I don't wanna explain bullshit over and over again, I'm selling this trash piece and actually buying a phone I won't settle for lol waited til 10.3.4 update for fix because bug only started happening since day I got 10.3.3
    Trash phone and feedback eventho I submitted 100s of logs I'm gonna recommend others not to buy this shit either lol
    MacLeo and ady_agar like this.
