23
[Submitted] Known Issues for OnePlus 7
  1. J1508070026278
    Gingerbread Oct 19, 2019
    J1508070026278 , via OnePlus 7 , Oct 19, 2019 :
    Regarding point number 4 - yes speed had slowed a bit immediately after installing the update , but after i did factory reset its as snappy as before.And battery life after factory reset is better than android 9.
    regarding point number 3 - finger print unlock animation can be changed thru 'Settings->Customization->fingerprint animation'
    #81
  2. zex_99
    Cupcake Oct 20, 2019
    zex_99 , via OnePlus 7 , Oct 20, 2019 :
    Hi. I've just updated my oneplus 7 to Oxygen OS 10.0.1 and i can't go to any vibration setting, when i press the any vibration settings (Call vibration, message, ...) my settings just stucks and when i close it for the first time and open my settings again the window is all white, after the second closing it gets fixed. i have video captured from this.
    Edit: it got fixed by itself, i don't know how. looks like system settings weren't fully loaded.
    #82
  3. darksavior21
    Froyo Oct 20, 2019
    #83
  4. O1571548089898
    O1571548089898 , Oct 20, 2019 :
    After the android 10 update the ringtone has automatically changed to some default sound which is audible enough. The worst part is I am not able to change the ringtone !
    #84
    zex_99 likes this.
  5. H1564320665829
    H1564320665829 , Oct 20, 2019 :
    Not able to play any video from file Manager. same file can be accessed and play from VLC app. seems bug.bhelp me out to resolve it.
    #85
  6. agam030
    agam030 , Oct 20, 2019 :
    thanks for your response...but I have a few doubts...
    1. Regarding your first point...so does that mean some residual files from the earlier OS are slowing the system down? if that's so, aren't there any other easier ways to clean the junk than factory resetting? Any case...these are just workarounds...hoping for an official permanent fix.
    2. It is with all the fingerprint animations. The animation lingers for a split second even after the phone is unlocked and the home screen is displayed...and it is clearly visible on the home screen for that time.
    #86
  7. J1508070026278
    Gingerbread Oct 20, 2019
    J1508070026278 , via OnePlus 7 , Oct 20, 2019 :
    not sure about the inner technical details about why factory reset is resolving the issues and if there are any easier ways of achieving the same result.
    regarding fingerprint animation, i am using the one titled 'Cosmos' and its pretty fast and does not linger on after the phone is unlocked.
    #87
  8. Deactivated User
    Oct 21, 2019
    #88
  9. A1571685890519
    Cupcake Oct 21, 2019
    A1571685890519 , via OnePlus 7 , Oct 21, 2019 :
    Please help me, post oxygen os update for one plus 7. I am facing problems when calling someone for the first time i won't be able to hear the opposite caller. I have to cut the call and dial again so the problem fixes temporarily. this is irritating
    #89
  10. amangu1
    Cupcake Oct 22, 2019
    amangu1 , Oct 22, 2019 :
    Auto rotation... My 6t doesn't want to auto rotate to landscape in the open beta OOS10. Anyone else has this issue? Will work on certain apps when I go full screen but not all apps.
    #90
  11. C1571061690138
    Cupcake Oct 24, 2019
    C1571061690138 , Oct 24, 2019 :
    I have to tap on the screen once to show the fingerprint icon. then I can unlock the screen. it is not possible to unlock directly by placing the thumb on the correct place while the screen is dark. I have the global rom. on my son's OP7 with EU rom it works fine.
    #91
  12. yywking
    Cupcake Oct 26, 2019
    yywking , Oct 26, 2019 :
    SMS delay after OxygenOS 10 update on my OP7, the messages just showing as "sending" for 5-10min, even worse if sending multiple SMS at the same time. Eventually they all get sent, but the delay is there, please fix. I have tested my SIM on another mobile and it worked perfectly without any delays, so it is the OP7 issue.
    #92
  13. S155
    Ice Cream Sandwich Oct 26, 2019
  14. T1572239548576
    Cupcake Oct 28, 2019
    T1572239548576 , Oct 28, 2019 :
    I recently updated my system and the apps unexpectedly closing and my net sleep has also decreased a lot after LTE what should I do.
    #94
  15. U1572057566440
    #95
  16. U1572057566440
    #96
  17. ashudahare
    Cupcake Oct 29, 2019
    ashudahare , Oct 29, 2019 :
    Battery Drain Issues after updating to oxygen os 10.
    Auto night detection is always on in normal mode there should be an option to turn of auto night detection.
    Auto Brightness doesn't works good
    #97
  18. Mr. Smith
    Eclair Oct 29, 2019
    Mr. Smith , Oct 29, 2019 :
    1. Pocket mode > the display turns on many times in my pocket...
    2. Notification LED simulation
    3. Improve main camera (e.g. video bitrate option) and selfie camera (see GCam: naturalness, sharpness, details)
    4. Ascending volume (ringtone and alarm)
    5̶.̶ ̶O̶p̶t̶i̶o̶n̶ ̶t̶o̶ ̶d̶i̶s̶a̶b̶l̶e̶ ̶t̶o̶g̶g̶l̶e̶ ̶b̶u̶t̶t̶o̶n̶s̶ ̶o̶n̶ ̶n̶o̶t̶i̶f̶i̶c̶a̶t̶i̶o̶n̶ ̶s̶h̶a̶d̶e̶ ̶(̶b̶a̶s̶i̶c̶ ̶s̶e̶c̶u̶r̶i̶t̶y̶.̶.̶.̶)̶ THANKS
    6. File explorer: FTP option
    7. File sharing app (see ShareMe by Xiaomi)
    8. Voice Recorder: option to disable or customize noise cancellation / normalization
    (e.g. Mode1: default, Mode2: lecture, speech, Mode 3: live music, Mode 4: OFF)
    9. Mobile data displaying on notification shade (like MIUI)
    10. Notepad: option to hiding and encrypting notes (like MIUI stock app)
    11. Custom ringtone for groups (e.g. family, co-workers, friends)
    12. Option to turning off charger after x% (like Sony Xperia "Charging optimisation" or Battery Charge Limit app)
    13. Voice call quality: the volume of incoming calls is often very low and whenever I use the speakerphone, they always hear badly.
    14. Option to hiding notch (as before...)
    15. Lockscreen background bug, when I play video or music player in the background (was good in version 9)
    16. Automatic brightness control works very poorly (was a LITTLE better in version 9)
    #98
  19. J1508070026278
    Gingerbread Oct 29, 2019
    J1508070026278 , via OnePlus 7 , Oct 29, 2019 :
    After Android 10.0.1 update.. i am facing sound distortion once every hour (for few seconds) while using my Boat Rockerz 255 Bluetooth earphones.. anyone else also facing this issue?
    #99
  20. DaveJames
    DaveJames , Oct 29, 2019 :
    Don't know if anyone else had this as well, but since the update from android 9 to 10.0.1 I had multiple issues with my dark theme. It switches back to white quite often, and then I change it back to black in the settings, it will reset again after X amount of time.
