Knox security system via OnePlus 6
  1. Manirathnamsomu
    Cupcake Feb 24, 2020
    Manirathnamsomu , via OnePlus 6 , Feb 24, 2020 :
    so I hope few of knew about the Knox security system used in samsung , can i know why the same is not used in one plus brands and if not any other security is used in one plus ? can you guys please share a word about this .
  2. pablofg1978
    Nougat Head Moderator Feb 24, 2020
    pablofg1978 , Feb 24, 2020 :
    Well, since oxygen os is a near stock android os, if Google itself thinks that this is not a required feature for Android, I guess that oneplus thinks the same.
  3. Horsault
    Nougat Moderator Feb 24, 2020
    Horsault , Feb 24, 2020 :
    To complete what is said above, OxygenOS offers you many ways to secure your device.
    - your whole storage is encrypted, so you can only access it after entering your PIN code / fingerprint.
    - you can hide some apps in hidden drawer, and lock access with your fingerprint, so that if you were to lend your unlocked device, access to these apps is protected.
    - you can store files in hidden folder, which works the same.
    - you can lend your device in guest mode, so that your whole storage is invisible.
    - you can set a secondary account to give access to a separate storage space and only to certain apps.
    Hope this will help.
