[Lab] Tempered Glass
  1. Vivekvarrier
    Cupcake Oct 28, 2019
    Vivekvarrier , Oct 28, 2019 :
    Hi everyone,
    A quick question. I have a Karbon case which I bought from Oneplus site itself. if i buy a 3d screen protector glass which is available in one plus website will it suite. i bought a full screen glass last day and had put it in my one plus 7t. but on the sides air bubbles were going in and the glass was coming off when i put back the case. can u guys advise.
  2. kvnreddy
    Froyo Oct 28, 2019
    kvnreddy , Oct 28, 2019 :
    hi I bought 3d glass from op store n they itself fix it..it works fine..I preferred instead of using some local ..pls go through one plus product's..only..
  3. GrayLanterns
    Cupcake Feb 18, 2020
    GrayLanterns , via OnePlus 7T , Feb 18, 2020 :
    hi, does OnePlus 7t come with a preinstalled tempered glass? is it sturdy enough? would you recommend replacing it with the original OP tempered glass that's available on the website?
  4. Varun1225
    Gingerbread Feb 18, 2020
    Varun1225 , via OnePlus 7T Glacier Blue , Feb 18, 2020 :
    I'm using Official OnePlus Tempered. I only recommend that to use. I have tried other too but they are bad and rune the experience of using the phone.
    It's oleophobic coating is on point with screen of phone itself and there are no sharp edges.
