Lag issue via OnePlus 7T
  1. sareen_garnaik
    Eclair Apr 10, 2021
    sareen_garnaik , via OnePlus 7T , Apr 10, 2021 :
    While playing PUBG
    Before OOS 11
    Le me * guys let's Rush for Bootcamp (Sanhok) ......my charge is 10 % but I don't feel any lag ...... playing with Battery Saver also shows no lag
    After update
    Now my 7T is similar to that of Realme X2 pro ( my 3 freinds having them ....they always say " Bhai lag hua bande hain " and me as a reply " Ky chij ka lag Bhai 🥺" )
    But after update everything changed Now I joined their Lagging techniques and no rush .Now I Don't Rush directly in Bootcamp instead go for side houses (but still lag like hell ) .
    If any pubg player had fixed this issue then plz help me
    My settings - smooth,90fps .
    And my divice kinda feel's slow too .( But it will be fixed after new update)
    surajnaidu123 likes this.
  2. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 10, 2021
    sareen_garnaik and Aaron2017 like this.
  3. sareen_garnaik
    Eclair Apr 10, 2021
    Nope not working.....I too reinstalled the pubg though, but still the same lag when lot of enemies comes near me .
    Caoimhín likes this.
  4. Caoimhín
    sareen_garnaik likes this.
  5. RAMEEZA2K15
    Gingerbread Apr 10, 2021
    RAMEEZA2K15 , via OnePlus 7T , Apr 10, 2021 :
    Yeah I think this will definitely work
  6. #6
  7. ShreyasPatil_
    Jelly Bean Apr 10, 2021
    ShreyasPatil_ , via OnePlus 8T , Apr 10, 2021 :
    Gaming Performance has been completely ruined in OOS 11. Even on 8T, it's the same. Meanwhile you can rollback to OOS 10 if stability and performance is priority. If features and security updates is the priority you can stick to OOS 11 along with these bugs.
    Also you can do this for additional help.
    You have to submit feedback via the community app to help the team debug the issues.
    1) Go to the home page
    2) Tap on the bottom right corner +icon
    3) Tap Feedback
    4) Select the category of issues you are facing
    5) Explain the issues and submit
    6) After that log kit would start capturing logs.
    7) Reproduce the steps by which the bugs occur.
    8) Go to status bar notification and tap on log kit notification and stop it after the issues are recorded.
  8. Sumanthkumar_10
