Lag issues via OnePlus Nord
  1. X1599638447931
    Cupcake Dec 7, 2021
    X1599638447931 , via OnePlus Nord , Dec 7, 2021 :
    In my device now I'm facing some lag and hang issues. While switching to another app it's showing lag . Since the device is with 12 gb of ram and then also showing the lag. If it's a update issue mate it fast . It's very hard to use the phone. And also I need to keep restarting .
    Make the issue solved fast and give me an update with a reply .
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Dec 7, 2021
    Liehjan , Dec 7, 2021 :
    What about the rest of your device storage, how much is used?
    Tokolozi likes this.
  3. X1599638447931
    Cupcake Dec 7, 2021
  4. H.S.S
    Jelly Bean Dec 7, 2021
  5. X1599638447931
    Cupcake Dec 8, 2021
  6. H.S.S
    Jelly Bean Dec 8, 2021
  7. X1599638447931
    Cupcake Dec 9, 2021
    X1599638447931 , via OnePlus Nord , Dec 9, 2021 :
    Going to reset is not an option
    My dats will be lost.
    Fix this issue .now also I'm facing the same issue I need to keep restarting .
  8. keithnyc
    Moderator Moderator Dec 9, 2021
    keithnyc , Dec 9, 2021 :
    Mate:
    This issue has been posted a few times already....in the search, you may find some answers instead of starting a new thread on the same topic----> https://forums.oneplus.com/search/528510658/?q=nord lag&o=date&c[title_only]=1
    If you feel you have a hardwareor software problem, you can also reach the developers here -----> https://forums.oneplus.com/feedback/
    If you think there is a specific issue with your phone, you can also contact customer support. Hope this helps
  9. H.S.S
    Jelly Bean Dec 9, 2021
    H.S.S , via OnePlus Nord , Dec 9, 2021 :
    There is a difference between soft reset and Hard reset.What i am saying is recovery mode.
  10. H.S.S
    Here are the steps for soft reset of your Android phone.
    Cache Partition stores temporary data for speeding up your android system. But some times you may need to clear this partition without erasing all other data.
    It only clears the Cache, your data is safe, just follow the steps :-
    1. Power off the phone.
    2. Wait until the device is completely off.
    3. Then press and hold the Power and Volume Down (-) buttons at the same time.
    4. Continue holding these two buttons during the initial OnePlus splash screen.
    5. When the OnePlus logo goes away, you can let go of these two buttons.
    6. And then wait until the phone boots into Recovery Mode.
    7. If you have a password set, you will have to enter the pin to decrypt(basically unlock access to storage) here.
    8. Tap on the language of your choice.
    9. Tap on the Wipe Data and Cache option.
    10. Tap on the Wipe Cache option.
    11. Tap the Yes option when asked to confirm.
    12. Wait for the phone to clear the cache partition.
    13. Then tap on the Reboot option to restart the phone.
