3
Lag!
  1. simon kn
    Donut Dec 1, 2020
    simon kn , Dec 1, 2020 :
    Hey, I'm getting seriously annoyed with my Oneplus 8t. Factory reset it today and installed all my apps. Keeps on randomnly lagging in apps that have run hours without problems. Suddenly they crash/stall the system and I have to shut down the app or reboot. There have been several updates but still issues. I cannot be the only one out there. Oneplus please solve this!!
  2. Shailender Sharma
    Marshmallow Dec 1, 2020
  3. Cervantes
    Moderator Moderator Dec 1, 2020
    Cervantes , Dec 1, 2020 :
    Hi
    You do not give information about the app with which you have problems
  4. ShreyasPatil_
    Ice Cream Sandwich Dec 2, 2020
    ConnectMrMJ likes this.
  5. Dresa91
    User of the Year 2016; Most Active User 2020 Dec 2, 2020
    Dresa91 , Dec 2, 2020 :
    contact the support
  6. razzor228
    OnePlus Accessory Tester Dec 2, 2020
  7. BEN_LUVS_CHICAGO , via OnePlus Community App , Dec 2, 2020 :
    That really is odd since the OnePlus devices are build for speed... I would suggest that you contact OnePlus technical support, I'm sure that would help. I hope that everything works out for you,best wishes.
  8. StefanStark
  9. Xpress0
    Gingerbread Dec 2, 2020
    SultanaDaaku likes this.
  10. simon kn
    Donut Dec 5, 2020
    simon kn , Dec 5, 2020 :
    Update: After the factory reset, I had lag issues for a short while and then everything has been running smoothly ever since ✌️
    Dresa91 likes this.
  11. Dresa91
    User of the Year 2016; Most Active User 2020 Dec 5, 2020
    Dresa91 , Dec 5, 2020 :
    This sounds great:)
  12. MarinosXx
    Gingerbread Dec 5, 2020
  13. O. Priya
    Honeycomb Dec 5, 2020
    O. Priya , via OnePlus Community App , Dec 5, 2020 :
    If you've your new phone, while configuring the device might have created caches and junk files. Clear the space from the phone. Restart it after doing the settings and clearing caches. No issues will be there then.
  14. JaiRathi
    Cupcake Dec 6, 2020
