Lagging alot and not using RAM
  1. Jxbfs
    Gingerbread Dec 8, 2018
    Jxbfs , Dec 8, 2018 :
    I'm running on the latest Beta of OnePlus 3.
    This device has been lagging for a while now,
    It shows RAM usage of 3.8gb inspite of having 6gb of ram.
    It is slow to swap apps, open apps and load them, specially Snapchat.
    Also, game loading and lagging is too much these days.
    What's the use of having 6gigs if it's just using 60% of it.
    Can anyone tell me any fix for this?
    Or alternatively the steps to get back to the Stock OTA version of Oxygen if that helps in any way.
  2. B_Wrath
    Nougat Dec 8, 2018
    B_Wrath , Dec 8, 2018 :
    You are a beta tester. You should know to search and read before creating a redundant thread.
    Go read the OB39 announcement thread.
  3. Jxbfs
    Yes, cool, but I've been facing serious device slow issue so I'm asking the community for a fix or if they're getting the same issues.
    And clearly, OnePlus has stopped listening to customers, so this is very i can only seek help.
  4. B_Wrath
    Nougat Dec 9, 2018
    B_Wrath , Dec 9, 2018 :
    Beta is closed for OP3/T. Move to stable.
    You have your fix and community thoughts on it in the beta thread.
    For all this, you need to visit the beta thread and not create redundant threads.
