Lagging issue in OP5
  1. manasgupta017
    Froyo May 11, 2018
    manasgupta017 , May 11, 2018 :
    phone is laggy after I updated to 8.1 Oreo , not always laagy but when it is that period is really frustrating. All the animation and transition effects becomes laagy. Is anyone facing the same issue after the update ?
    S_ourab_h likes this.
  2. the_o2
    OnePlus 9 Series Expert Community Expert May 11, 2018
    the_o2 , May 11, 2018 :
    Restart your phone once and check, if still problem then clear the cache partition from recovery mode.
  3. manasgupta017
    Froyo May 11, 2018
    I restarted my phone after that it works nicely for some days . I will try clearing cache from recovery mode
  4. the_o2
    Yup, do and tell, btw you know the process..
  5. manasgupta017
    Froyo May 11, 2018
  6. G_viraj_kamdar_YRiN
    Cupcake May 11, 2018
  7. gud boy
    Eclair May 12, 2018
    gud boy , May 12, 2018 :
    after this recent update of Android 8.1.0. below issues have arisen:
    1. suddenly, the 'MY JIO' App is opening by itself, whenever the phone reboots or when you open switch on your phone. Anyone facing the same issue.
    how to remove this bug/ issue? pls help.
    2. no 'Developer option' showing. where it has gone?
    pls address the issues and reply with remedy?
  8. manasgupta017
    Froyo May 13, 2018
    manasgupta017 , May 13, 2018 :
    try clicking on build number multiple times
  9. manasgupta017
    Froyo May 13, 2018
    #gudboy try doing the step given by #sandeep
  10. Mehmetozmen
    Froyo May 13, 2018
    Mehmetozmen , May 13, 2018 :
    I have same issue but only thing that you all can do "feedback" . Give informations to bug hunters. It will be solve next update. I was going say wipe cache but not work all.
  11. Abhinav Patri
    Cupcake May 13, 2018
