Lagging issue via OnePlus 7 Pro
  1. shishir06
    Cupcake Jul 25, 2021
  2. Boogeyman_real
    Gingerbread Jul 25, 2021
    Boogeyman_real , via OnePlus 7 Pro , Jul 25, 2021 :
    Wait for the new update or start from scratch. Take backup of your data and factory reset your phone.
    I do know that factory reset is not an elegant solution. but that's the only way out.
    Artemus. likes this.
  3. nerdkabir
    Jelly Bean Jul 26, 2021
    nerdkabir , via OnePlus 7 Pro , Jul 26, 2021 :
    Chose "wipe cache" ONLY. (Do take a backup of your phone, though wipe cache option will not remove any data).
    Turn the phone off.
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot
  4. KluGe
    Lollipop Jul 26, 2021
  5. shishir06
    Cupcake Jul 26, 2021
  6. shishir06
  7. shishir06
    shishir06 , via OnePlus 7 Pro , Jul 26, 2021 :
    Not worked..
  8. nerdkabir
    Then try taking a backup of your device and do a factory reset. Check if that helps, all apps and camera working fine or not. If everything is good, only then restore your data back. Else try doing factory reset a few more times.
  9. Z1612187578731
    Gingerbread Jul 26, 2021
  10. Aaron2017
    Aaron2017 , Jul 26, 2021 :
    At least read a little, not only did you basically copy someone else's answer, OP has already said it didn't work as well. But you don't care that his problem doesn't get fixed now do you, as long as you get your precious RP.
  11. Z1612187578731
    Gingerbread Jul 27, 2021
    Z1612187578731 , via OnePlus 7 Pro , Jul 27, 2021 :
    Thanks for reminding my mistake.
