26
Latency Issue: Bullets Wireless Z
  1. darkseid93
    Froyo May 15, 2020
    darkseid93 , May 15, 2020 :
    Got my Wireless Z day before. They sound right for the price. The bass is better than what I thought. But the low latency mode isn't working for me with the FNATIC MODE. I'm getting around 300ms of latency.
    Tested via: https://play.google.com/store/apps/details?id=barum.life.audiotester
    Is there anything wrong that I'm doing or should be doing to reduce that lag to the stated 110ms, please let me know.
    Device: OnePlus 5
  2. darkseid93
    Froyo May 18, 2020
    B1570126484296 likes this.
  3. inferno0230
    Donut May 19, 2020
    inferno0230 , May 19, 2020 :
    Iamaki08
    Is there anything wrong that I'm doing or should be doing to reduce that lag to the stated 110ms, please let me know.​
    Same with me too
    I am using 7T and even in fanatic mode i am getting 200-300ms latency and in normal mode 400ms
    Here's a test video-
    https://drive.google.com/file/d/10QBNF0f-ProvuF0kbImjJ_IX-qIZXriz/view?usp=drivesdk
    But one time i got 110 ms idk how
    I just randomly open my game for training and i noticed that the latency is decreased
    I think earphone are not faulty , The software and earphones can't recognise each other which causes this and also it is just launched recently
  4. darkseid93
    Froyo May 19, 2020
    darkseid93 , May 19, 2020 :
    Yeah. I noticed the same. I was on a call while playing PUBG M and the latency was almost down to a 110ms, but can't have to keep calling people just to maintain the latency of the bullets. Let's hope ONEPLUS comes up with a solution for this.
    I tried it on the Open Beta Android 10 as well as Stable 9.0 . Not working on either.
    G_Nishant_Gauns_KoCI likes this.
  5. inferno0230
    Donut May 19, 2020
    inferno0230 , via OnePlus 7T , May 19, 2020 :
    Iamaki08
    I tried it on the Open Beta Android 10 as well as Stable 9.0 . Not working on either.​
    i contacted them
    that said to reset earphone to solve this issue but it didn't work fir me
    if u wanna reset it just press and hold vol+ and vol- while disconnected
    AravindAnbu likes this.
  6. darkseid93
    Froyo May 19, 2020
    Okay, I'll try to do that. If nothing works I'll just go back to Analog. Thank the lord for my OP5 has a audio jack. Will keep you posted incase there are any updates.
  7. inferno0230
    Donut May 19, 2020
    Yes i am suffering cause i can't play even if i have a device XD
  8. darkseid93
    Froyo May 19, 2020
    Yeah. What do you think about the audio output and mic performance? I found it satisfactory.
    Pt25 likes this.
  9. inferno0230
    Donut May 19, 2020
    My Mic sometimes picks up background noise but its fine cause it only picks noise if its too loud
  10. darkseid93
    Froyo May 19, 2020
    I've tried it outdoors as well. Mine didn't pick up too much noise. Just reset the bullets. Trying the audio tester.
    Edit: Still on 300ms.
  11. darkseid93
    Froyo May 19, 2020
  12. darkseid93
    Froyo May 19, 2020
    I'm using the Oneplus 5 while Inferno here is using Oneplus 7T. So this isn't a device specific issue.
    inferno0230 likes this.
  13. inferno0230
    Donut May 19, 2020
  14. inferno0230
    Donut May 19, 2020
  15. darkseid93
    Froyo May 19, 2020
  16. darkseid93
    Froyo May 19, 2020
    To Add Audio Tester in Fnatic mode:
    Settings >Utilities> Gaming Mode> Scroll to the bottom and
    use Add apps for gaming mode.
  17. AakarshDubey
    Froyo May 21, 2020
    AakarshDubey , via OnePlus 6T , May 21, 2020 :
    Yeah the same issue is with me.. I tested the audio tester with realme buds air low latency and it is giving around 130ms but the wireless z are giving a result of around 300 even when the fnatic mode is on.. Hopefully oneplus fixes this soon or else it's just waste to highlight a feature which doesn't actually work.
  18. aakashsood
    Jelly Bean May 22, 2020
    aakashsood , via OnePlus 5T , May 22, 2020 :
    Yup same issue for me. I wasn't expecting such a mediocre bug from OnePlus. I mean you don't even have to apply some kind of scenario to test it. it's right there in front of our eyes.
    I hope there is a solution and it should be fast.
    abpanchali and Vinay_Rules like this.
  19. darkseid93
    Froyo May 22, 2020
  20. r4rahulspillai
    Cupcake May 22, 2020
    r4rahulspillai , via OnePlus 5T , May 22, 2020 :
    I am having the same issue with my OnePlus 5T. There's no latency issue with any other apps or games or even while watching movies. I am only facing it while on Pubg
