28
Latency Issue: Bullets Wireless Z
  1. abpanchali
    Gingerbread May 29, 2020
    abpanchali , via OnePlus 6 , May 29, 2020 :
    Exactly! I trusted TK Bay blindly. I don't know if the problem with Bluetooth or the reviewers!
    #61
    darkseid93 likes this.
  2. darkseid93
    Froyo May 29, 2020
    darkseid93 , via OnePlus 5 , May 29, 2020 :
    I feel you brother. I just got the Android 10 update. Let's see if it helps on the Oneplus 5
    #62
  3. abpanchali
    Using the Audio tester app on the wireless Z, try playing sounds only on the left ear. Does it play only on the left ear? Mine can't isolate the left ear but can do for the right.
    #63
  4. darkseid93
    Froyo May 29, 2020
    The other features are working fine. I get the audio in the desired channel. Also, updated to Stock Android 10. No signa of latency improvement.
    #64
    abpanchali likes this.
  5. abpanchali
    What phone are you using?
    #65
  6. darkseid93
    Froyo May 29, 2020
    I'm using the Oneplus 5. I've got an unlocked bootloader and twrp recovery. The rest is pure stock.
    #66
  7. B1570126484296
    Cupcake May 29, 2020
    B1570126484296 , May 29, 2020 :
    hey so i too bought them a couple of days ago and the latency is pretty frustrating and whats more disturbing is that the audio lag is present even when i use my laptop. so i dont think it is oneplus mobile related.....
    they really need to find a solution to this problem quickly.
    #67
  8. B1570126484296
    #68
  9. vIsH00
    Cupcake May 31, 2020
    vIsH00 , via OnePlus 6T , May 31, 2020 :
    I'm also facing the latency issue while playing games. Latency is around 200-300. When I'm on call the latency decreases significantly but media sound quality becomes poor. If anybody knows how to fix this then please help!
    #69
  10. darkseid93
    Froyo May 31, 2020
    darkseid93 , via OnePlus 5 , May 31, 2020 :
    We're all trying to figure out a solution for this. OnePlus isn't responding.
    let's see if a near update pushes the solution for us
    #70
    Yashwanth Sirivella likes this.
  11. 223varun
    Eclair May 31, 2020
    223varun , May 31, 2020 :
    The near update will be 2 months away.... They took the lazy route by testing it on the oneplus 8 and didnt focus on the older generations which is why we are having this problem.
    The latest update for the oneplus 7 series has fixed the problem for them(the dolby atmos integration).... I have a 6t, weird that the 7 series gets that update and the 6 series have to wait for another couple of months for it.
    #71
    Nikgreppi and sumit99 like this.
  12. sumit99
    Donut May 31, 2020
    sumit99 , via OnePlus 5T , May 31, 2020 :
    seem like no fix for the OP 5/5T then. My OP5T just got updated to Oxygen10.0.0. Still not fix for the audio latency issue with BWZ.
    #72
  13. anasazeem
    Cupcake Jun 1, 2020
    anasazeem , Jun 1, 2020 :
    Forget PUBG, even on YouTube videos you can easily make out that there is a synchronization issue in the headset. Waiting for OnePlus to at least deliver what you promise, even the cheaper Xiaomi neckband has better latency than these. Really looking forward to a software patch for these.
    #73
  14. 223varun
    Eclair Jun 1, 2020
    223varun , Jun 1, 2020 :
    I have no issue with watching videos.... My issue is only gaming...
    #74
  15. Y1508835174398
    Cupcake Jun 2, 2020
    Y1508835174398 , Jun 2, 2020 :
    I have brought OnePlus bullets wireless Z 2 days back....low latency mode is not working....there is 300ms difference as said above....my device is OP5 with oxygen OS version 10.
    What to do, to avoid it.
    #75
  16. darkseid93
    Froyo Jun 2, 2020
    darkseid93 , via OnePlus 5 , Jun 2, 2020 :
    Well as of now, it's only working with a latency of 110ms when you're in a call. For the other times you'll have to suffer just as us rest.
    They fixed 7 series with a ota upgrade and dolby atmos.
    I don't think we are not going to get that update so looking at other options is a more fruitful way
    #76
  17. Robertbaratheon
    Donut Jun 3, 2020
    Robertbaratheon , Jun 3, 2020 :
    OnePlus 6 Received an update today but it didn't help with the latency at all. It's still the same
    #77
  18. Arghya_Pramanick
    Cupcake Jun 5, 2020
    Arghya_Pramanick , Jun 5, 2020 :
    Same latency issue for me on oneplus 6t. With or without Fnaatic mode I m getting around 400ms ping on games and videos on chrome, twitch,etc. Youtube Netflix seems to be fine though
    #78
  19. Ravin C
    Cupcake Jun 5, 2020
    Ravin C , Jun 5, 2020 :
    Did upgrading the Oxygen OS helped with the reduction of latency?
    #79
  20. Ravin C
    Cupcake Jun 5, 2020
    Did the latest update for one plus 7 series solved the issues with latency?
    #80
