28
Latency Issue: Bullets Wireless Z
  1. inferno0230
    Donut Jun 6, 2020
    inferno0230 , via OnePlus 7T , Jun 6, 2020 :
    latest update for 7 series device fixed latency issue
    #81
    Ravin C likes this.
  2. Ravin C
    Cupcake Jun 6, 2020
    Ravin C , Jun 6, 2020 :
    I am using one plus 7 and earlier I also faced same issue on 10.3.2 update i used to get Audio latency around 200-300 but after recent update 10.3.3 the issue has been solved so when i checked audio latency on the Audio tester with fnatic mode i got latency of 110ms asclaimed. The new update brings dolby support to the wireless Z. I also played pubg and the gaming experience was amazing. So try to update your phone to Oxygen os 10.3.3 and issues will be resolved.
    #82
  3. Ravin C
    Cupcake Jun 6, 2020
    Thanks a lot just updated my one plus 7 and the latency is now reduced to 110ms.
    #83
  4. Arghya_Pramanick
    Cupcake Jun 8, 2020
    #84
  5. darkseid93
    Froyo Jun 8, 2020
    darkseid93 , via OnePlus 5 , Jun 8, 2020 :
    Us older members with the older phones such as the 5, 5t and above upto 6t series are still struggling. I don't think there would be any oncoming updates for the older ones so we will have to suffer with the latency.
    @Abdul B. Kindly provide details as to what should be done to solve this.
    #85
  6. 223varun
    Eclair Jun 9, 2020
    #86
  7. Prasannabalaji1402
    Donut Jun 9, 2020
    Prasannabalaji1402 , Jun 9, 2020 :
    I was worried about this latency issue that's been rolling around.
    should I buy bullets z or save up and buy bullets 2.?
    #87
  8. Q1582113765920
    Cupcake Jun 9, 2020
    Q1582113765920 , Jun 9, 2020 :
    Hey all please help me i just ordered these earphones for the gaming only i i have one plus 7t screenshot attached i guess it is oxygen 10.3.2. please tell me if these are not good with there latency on 7t then i will cancel my order i already have jbl and boat bt earphones i ordered these juat bcz of low latency if it is not working then they are useless for me.
    #88
  9. darkseid93
    Froyo Jun 9, 2020
    darkseid93 , via OnePlus 5 , Jun 9, 2020 :
    From what I've read around here, It's working perfectly on all devices 7 and above as of now. So your 7T should be fine.
    #89
  10. Q1582113765920
    Cupcake Jun 9, 2020
    #90
  11. praypratyay
    Cupcake Jun 9, 2020
    praypratyay , Jun 9, 2020 :
    what is the plausible solution for this?
    I tried everything disabling HD AUDIO and resetting the BWZ.
    I AM USING OP5T and this Pubg issue is very frustrating.
    Has anyone with op5 have resolved the problem?
    when will the update fix this issue?
    #91
  12. ashil17
    Donut Jun 10, 2020
    ashil17 , Jun 10, 2020 :
    Me too.I bought because they advertised that the low latency also works with op5 onwards.
    Now I know they are frauds
    #92
    Venkatesh mummidi likes this.
  13. ashil17
    Donut Jun 10, 2020
    Atleast put a return option on their site.just feel sad for burning 2k rs
    #93
  14. praypratyay
    Cupcake Jun 10, 2020
    praypratyay , Jun 10, 2020 :
    Please make OnePlus know about this problem ASAP.
    If you know how to fix it, do post the solution here.
    #94
  15. pavanraghavaraju
    Gingerbread Jun 10, 2020
    pavanraghavaraju , Jun 10, 2020 :
    I purchased Bullets Wireless Z Mint edition.
    I am using with OnePlus 7T Pro.
    Hearing music is good.
    While making calls end user are hearing me very far and voice is less.
    There is lot of latency 2 seconds delay.
    I purchased from OnePlus.in
    I have asked for replacement or else I need my money back. I previously had Boat rockers 255. Which is awesome.
    I made a big mistake by buying Bullets Wireless Z.
    #95
  16. Ravin C
    Cupcake Jun 11, 2020
    Ravin C , Jun 11, 2020 :
    U have to wait for update oxygen 10.3.3 which solves the issue. Even i was facing the same issue initially but once i upgraded by software the latency issue got fixed. I checked it in the audio latency test app and even played pubg it worked fine.
    #96
  17. kartik.op
    kartik.op , Jun 11, 2020 :
    Same is the case with with pair of Bullets Wireless Z earphones. Latency is very high even in fnatic mode!!
    #97
  18. ashil17
    Donut Jun 11, 2020
    ashil17 , Jun 11, 2020 :
    What phone do you use?
    Iam getting latency between 200 and 300
    #98
  19. darkseid93
    Froyo Jun 11, 2020
    darkseid93 , via OnePlus 5 , Jun 11, 2020 :
    If you bought it via the Oneplus Website, there is no return option because they inly provide replacement. I spoke to the customer care guys on Whatsapp. This is what they had to say.
    #99
  20. darkseid93
    Froyo Jun 11, 2020
    The 10.3.3. update as of now is only available for the Op7 and above devices.
