135
[Latest 3.2.4] [OnePlus 3] Mirrors for official Oxygen OS ROMs and OTA updates
  1. inffy
    KitKat Jun 17, 2016
  2. Naman Bhalla
    Recognized developer Recognized Developer Jun 17, 2016
    inffy likes this.
  3. Ricky1998
    Cupcake Jun 17, 2016
  4. robbiegast
    Honeycomb Jun 17, 2016
    Naman Bhalla likes this.
  5. Naman Bhalla
    Naman Bhalla , Jun 17, 2016 :
    Unfortunately, OnePlus doesn't publish its fastboot images ever. Only OnePlus support has access to those files which they use to correct phones. It is also Qualcomm tool along with fastboot images. So, I hope someone gets that to us if he ever contacts support.
    nate0 likes this.
  6. subodhsg
    Froyo Jun 17, 2016
    subodhsg , Jun 17, 2016 :
    Thanks!!
  7. Ricky1998
    Ricky1998 , Jun 17, 2016 :
    ok tanks i flashed cm13 and battery life was horrible any news on paranoid android or should i revert to stock
  8. Naman Bhalla
    PA might come anytime this week for sure.
  9. Ricky1998
    ok sweet it looks like a well thought out rom hopefully less buggy with good battery back up
  10. qvert
    qvert , Jun 17, 2016 :
    any idea how i can flash this?
    i tried in the stock recovery but there is no option
    Just sideload via ADB but not directly from storage?
    Schifko likes this.
  11. Alvie
    The Lab - OnePlus 5T Reviewer Jun 17, 2016
    Alvie , Jun 17, 2016 :
    Is there an Install from local option?
    If not, you should probably flash TWRP first and then flash the ROM.
  12. samish.arora
    Froyo Jun 17, 2016
    samish.arora , Jun 17, 2016 :
    PA is now out on official website
  13. Naman Bhalla
    Recognized developer Recognized Developer Jun 18, 2016
    Naman Bhalla , Jun 18, 2016 :
    The device comes encrypted by default. So, install via Local isn't possible. Go for adb sideload.
    I knew that ;)
    Alvie likes this.
  14. iRajeshRajput
    Honeycomb Jun 18, 2016
  15. Hariragh
    The Showcase Reviewer Jun 18, 2016
  16. Martin Hotmann
    Community Veteran Jun 18, 2016
  17. Avi07vijay
    Cupcake Jun 18, 2016
    Avi07vijay , Jun 18, 2016 :
    @Naman Bhalla,
    Thanks for the root guide, worked everything fine as expected ..
    After rooting, 3.1.2 update just popped up!! Should I just flash the signed flashable zip(it's actually 3.1.2, not 3.1.3..ryt??).. Will I have to root again after flashing?
  18. jpswer
    Jelly Bean Jun 18, 2016
    jpswer , Jun 18, 2016 :
    Can be moved to the Custom OP3 Software section now.
    Let the real fun begin now we've got that section available hey @Naman Bhalla?
    #38
  19. iRajeshRajput
    iRajeshRajput , Jun 18, 2016 :
    Yes FLah the full rom zip file via recovery and yes you have to root it again
    #39
  20. Sahilk0369
    Sahilk0369 , Jun 18, 2016 :
    3.1.3 is already out??
    #40
