135
[Latest 3.2.4] [OnePlus 3] Mirrors for official Oxygen OS ROMs and OTA updates
  1. LELBOT
    Donut Jun 25, 2016
  2. Funk Wizard
    Moderator Moderator Jun 25, 2016
    LELBOT likes this.
  3. jcespi2005
    Ice Cream Sandwich Jun 25, 2016
    jcespi2005 , Jun 25, 2016 :
    12Mb from 3.1.3 or from 3.1.2? Should be different though...
  4. Sgnoogle
    Eclair Jun 25, 2016
    Sgnoogle , Jun 25, 2016 :
    Hi guys!
    Just a quick question: now I'm on HydrogenOS, am I able to flash these signed OxygenOS firmware directly from the local update section in the update menu?
    Also, when I am on OxygenOS (with no root and locked bootloader) am I able to receive Ota updated directly from the update menu?
    Thank you very much! :)
  5. TheChigga
    Cupcake Jun 25, 2016
    TheChigga , Jun 25, 2016 :
    Hi!
    I bought a OnePlus 3 from China that runs on Hydrogen OS, How can I flash Oxygen OS on my One Plus 3?
    Looking forward to your soonest reply.
    Thank You!
  6. Funk Wizard
    Funk Wizard , Jun 25, 2016 :
    Should be from 3.1.3 not sure though all speculations, we need to wait it out
    Yes and Yes
    Just download load the full 3.1.3zip and sideboard it via recovery
    https://forums.oneplus.net/threads/...root-non-root-users-without-data-loss.451853/
    Sgnoogle likes this.
  7. jcespi2005
    I doubt was from 3.1.3, cause is not an official OTA, mine came with 3.1.0, and OTA stock to 3.1.2. And is all, so seems there's no 3.1.3 OTA, and this is why i think could be more than one path to 3.1.4 (from 3.1.3 and from 3.1.2) with different sizes...
  8. Funk Wizard
    As i said all speculation, though your logic has logic :D
    I just said 12mb as the screenshot says so
  9. Sgnoogle
    Eclair Jun 25, 2016
    Thank you for the quick answer Funk Wizard!
    But, now I have another question: why do you suggest to use the ADB sideload installation instead of just using the stock update menu? (of course I'm talking for unrooted users)
    Thanks!
  10. Naman Bhalla
    Recognized developer Recognized Developer Jun 25, 2016
  11. Funk Wizard
    Yes that's the only option for unrooted users with Stock recovery as the os is encrypted
  12. Sgnoogle
    Eclair Jun 25, 2016
    mmm ok, so I have to sideload it, not install from the update menu! (less than Hydrogenos isn't encrypted, but I don't think so!)
    PS: does oem unlocking option in the developer menu adjust anything?
    Thanks :D
  13. Naman Bhalla
  14. l3art
    Gingerbread Jun 25, 2016
    l3art , Jun 25, 2016 :
    Thnx, because o this thread I was able to update from 3.1.2 to 3.1.3 using TWRP.
  15. Magnetic Nerd
    Jelly Bean Jun 25, 2016
    Magnetic Nerd , Jun 25, 2016 :
    So did OP pull the 3.1.3 update because of the 3.1.4 coming soon or what's going on? No one seems to have gotten an OTA for it
  16. Funk Wizard
    not needed if you are not unlocking the bootloader, just sideload the zip for installation
  17. cellimar
    Cupcake Jun 28, 2016
    cellimar , Jun 28, 2016 :
    there are some minimum system requirements for other devices?
    or which devices support which version of oxygenos?
    thank you very much
  18. Naman Bhalla
    Recognized developer Recognized Developer Jun 28, 2016
    Naman Bhalla , Jun 28, 2016 :
    These are only for OnePlus 3
  19. cellimar
  20. Alvie
    The Lab - OnePlus 5T Reviewer Jul 2, 2016
    Alvie , Jul 2, 2016 :
    @Naman Bhalla I used fastboot format userdata to decrypt my phone, but it still says encrypted in settings. Is it supposed to be like that? Does it only decrypt the partitions?
