114
ROM Latest ColorOS mod
  1. DerNicoHalt
    Gingerbread May 30, 2015
    DerNicoHalt , May 30, 2015 :
    I don't know what that has to do with my post about TWRP 2.8.6.1, little cupcake ;)
  2. RedBullX
    Cupcake May 30, 2015
    RedBullX , May 30, 2015 :
    How do i install de original version? its giving me an error "this is made for ONE not A0001" then i got another related with binary...
    Only 2.0.60 mod working...
  3. Shrapnelist
    Jelly Bean May 30, 2015
    Shrapnelist , May 30, 2015 :
    unzip into the folder
    open updater script in meta inf / com / google / android /
    remove the first line (the whole line) that says
    I used notepad++
    this package is for ONE
    save it
    then zip the folder
    Gonzo01 and relic242 like this.
  4. RedBullX
    Thanks Mate! Appreciate the help.
  5. Shrapnelist
    no problem thats where I got stuck too lol
    Gonzo01 likes this.
  6. RedBullX
    U mean this whole line?
    getprop("ro.build.product") == "ONE" || abort("This package is for \"ONE\" devices; this is a \"" + getprop("ro.build.product") + "\".");
    relic242 likes this.
  7. r3trodisco
    Eclair May 30, 2015
  8. yourandroidfan
    Eclair May 30, 2015
  9. mauj85
    mauj85 , May 30, 2015 :
    If u love the os u can use nova launcher or if want to keep ui also along with coloros try appswap app within color launcher
    Edit : its exact name is App Swap n available on play store
    yourandroidfan likes this.
  10. kcpatel83
    kcpatel83 , May 30, 2015 :
    What software do you use for zip/unzip?
    In my case, I used 7zip and it failed to flash the zip created.
  11. Shrapnelist
    That's right :) tell me if it worked
    7zip works for me. That's weird. what os are you running? linux ? windows? what version? I used windows 7 . It can also unzip and zip stuff but I like to use 7zip
  12. RedBullX
    Nah man, it just fails, tried using the mod script, also fails, tried replacing the "ONE" for "A0001" no success so far. Any more ideas?
  13. Shrapnelist
    try replacing it with bacon
  14. kcpatel83
    I use Windows 7. I tried both 7zip and Windows native zip. But both failed to flash. Weird.
  15. victorcheah
    Donut May 31, 2015
    trashabwoy, mammenj and mauj85 like this.
  16. mauj85
    Gingerbread May 31, 2015
  17. CBpbxEcmecmBeH
    Jelly Bean May 31, 2015
    CBpbxEcmecmBeH , May 31, 2015 :
    you should really try Xplore file manager: edit whatevet file inside the zip without unzipping it. It works perfectly, have been using it forever ;)
    getprop("ro.build.product") == "A0001"
    should be the only line you have to edit, otherwise there's something else that's wrong
    Shrapnelist likes this.
  18. sureshsury
  19. rastojusko
    Eclair May 31, 2015
  20. CBpbxEcmecmBeH
