Latest update Wifi connection issue
  1. ojas94
    Cupcake Feb 13, 2015
    ojas94 , Feb 13, 2015 :
    Im facing the same problem. Any suggestions?
  2. shivagundam
    Cupcake Feb 15, 2015
  3. frank.bevers
  4. pcmarcel
    Honeycomb Feb 15, 2015
    pcmarcel , Feb 15, 2015 :
    Huh... didn't you find it in the box ??
  5. Waelthus
  6. mice.co
  7. prasannapm
  8. engrobertofernandes
    Cupcake Feb 16, 2015
    engrobertofernandes , Feb 16, 2015 :
    I'm having the same problem... somewhere in the forums someone said that this problem might be a problem with auto frequency band...
    Try this possible solution:
    - Settings > Wi-Fi > tap Menu button > Advanced >
    The "Wi-Fi Frequency Band" setting is probably set to "Auto". Change it to "2.4 GHz only" and see if it helps, for me it did :)
  9. k_matusz
  10. mubdea
  11. nullptr
  12. 3arrab
  13. venkatg.net
    Froyo Feb 16, 2015
  14. jbaldacchino
  15. jmorales21
    Cupcake Mar 17, 2015
  16. johnairey
    Cupcake Apr 3, 2015
    johnairey , Apr 3, 2015 :
    Hi I am having the same issue - did you resolve this ? I am having to turn the WiFi off and back on every time I loose a saved WiFi location. Thanks
  17. anoopsharma1391
    Cupcake Apr 20, 2015
    anoopsharma1391 , Apr 20, 2015 :
    I AM HAVING THE SAME PROBLEM..PLZ HELP
  18. Nopanand
    Froyo Apr 30, 2015
    Nopanand , Apr 30, 2015 :
    Mine, Now wifi problem connecting and overheating, reboot can solve just a short time, then happen again.
