3
[Submitted] LED not working on 10.3.1
  1. DrJMun
    KitKat Feb 6, 2020
    DrJMun , Feb 6, 2020 :
    I recently updated to 10.3.1 (yes, I reformatted) and everything is working well except for the LED light.I use Textra, Previous to the update the LED light would turn on allowing me to immediately know when I've received a message. Since the update the light does not come on. It is working because it goes RED when in battery saver mode and BLUE when charging. I tried using Messages and the light does not go on.
    A Trendafilov, jgould30 and iamrj like this.
  2. A Trendafilov
    Cupcake Feb 7, 2020
    DrJMun and johndirch like this.
  3. johndirch
    Froyo Feb 13, 2020
    johndirch , via OnePlus 6 , Feb 13, 2020 :
    me too. the same bug. I didn't have this problem on 9. you can't change the led color now in an apk.
    Viber notification don't light on.
    DrJMun and A Trendafilov like this.
  4. jgould30
    Cupcake Feb 29, 2020
    jgould30 , Feb 29, 2020 :
    I've had this same issue since the Android 10 rollout. Notification lights have been an issue for multiple apps. I suspect with them dropping the notification light in newer models they just removed the code and pushed it out to older phones like the 6. please fix this, it's super annoying.
    A Trendafilov and DrJMun like this.
  5. Z1583122955866
    Cupcake Mar 2, 2020
    Z1583122955866 , Mar 2, 2020 :
    My notification light doesn't work for some messaging apps as well (since Android 10 update on my 6). Works for every other type of notification. Please fix asap.
  6. johndirch
    Froyo Mar 14, 2020
    johndirch , via OnePlus 6 , Mar 14, 2020 :
    I have installed 10.3.2. The same problem. in Viber when I have a message the led don't blink. also I can't change the color of led on application I want. I had on Viber purple. now I can't change. there isn't the option to change.
  7. DrJMun
    KitKat Mar 16, 2020
