Led notification not working
  1. anulagarwal
    Gingerbread Dec 23, 2016
    anulagarwal , Dec 23, 2016 :
    Since my marshmallow update my led notifications have stopped working. The led light only works while charging, any suggestions? I thought this update would fix it but it didn't.
    Help me
  2. jkb114
    Lollipop Dec 23, 2016
    jkb114 , Dec 23, 2016 :
    Can you try clearing the device cache and see if it improves?
    If it doesn't can you perform a clean flash of the OS
  3. G_Divya_Geryani_oixW
    Cupcake Dec 23, 2016
  4. jkb114
  5. gsumit85
    gsumit85 , Dec 23, 2016 :
    Are you using original Flip cover provided by OnePlus ??? if yes then stop using that.
    that issue was also with me ... after removing flip cover and using only back cover, problem solved after this new update 3.5.5.
    LED notification start blinking .... Cheers
  6. G_Divya_Geryani_oixW
  7. G_Divya_Geryani_oixW
  8. jkb114
  9. G_Divya_Geryani_oixW
  10. gsumit85
    have u updated your OS to 3.5.5....!!
    first update ... problem might be solved...
  11. G_Divya_Geryani_oixW
    G_Divya_Geryani_oixW , Dec 23, 2016 :
    Yes I updated it today only
  12. Rachit_7799
    Froyo Dec 23, 2016
  13. G_Ibrahim_Ateyat_JdPL
  14. Satendra.Bundela
    Cupcake Jan 26, 2017
    Satendra.Bundela , Jan 26, 2017 :
    Issue solved
    Issue is solved for me.
    For me the issue was linked to notification of whats app.
    In settings go to notification
    Select whats app
    Turn off show on lock screen option.
    Check you should be able to view led notifications.
    Once done you can re-enable the option of show on lock screen, everything will start working like charm.
  15. SIDNANCHE
    Cupcake Jul 9, 2018
    SIDNANCHE , Jul 9, 2018 :
    my led notification not working only I connect to charging it's working otherwise it's not working plz help me
