Led set to orange but shows blue when charging oneplus 5t
  1. Drewdown
    Cupcake Dec 1, 2017
    Drewdown , Dec 1, 2017 :
    led set to orange but showing blue when charging? I tried dto set the led to default and it's still blue. I rebooted the phone after applying the setting but it's still showing blue.
    if I remove the charger then plug it back in it shows orange for about 1 second then goes blue. I have no notifications and the battery is 84%.
    Nothing is set to blue I don't know why it's showing. Does anyone know how to fix this?
    EaPhone likes this.
  2. T1511826350460
    Eclair Dec 1, 2017
    Drewdown likes this.
  3. MentalDraco
    Marshmallow Dec 1, 2017
    MentalDraco , Dec 1, 2017 :
    you guys are killing me, if you use the dash charger it will ALWAYS be blue, that shows that dash charge works, plug it in a USB port or a power bank and it will be the color you set
  4. Drewdown
    Cupcake Dec 1, 2017
