lens flare issue at one plus 7 pro
  1. soumen1321042
    Cupcake Oct 2, 2019
    soumen1321042 , Oct 2, 2019 :
    Some of the pics that are taken between 5-6 pm and sometimes at night are having that issue, daylight pictures are good and this problem never happens at day light, to make the problem more clear I have attached some camera samples
  2. #2
    Bouncer71 likes this.
  3. soumen1321042
    Cupcake Oct 3, 2019
    soumen1321042 , Oct 3, 2019 :
    I have cleaned my lens, this prblm occurs also after cleaning the lens thn after sometime it disappears, what can I do?
  4. OStratoO , via OnePlus 7 Pro Nebula Blue , Oct 3, 2019 :
    You need to have something on the lens. Lens screen protector or moisture. Or the phone case, try without it.
    Clean the lens with some product a try again I have the same pictures as you in a football stadium. 1st bat, I clean, 2nd bad because there is some moisture, than I use some water to help me clean and voila the 3rd photo is OK
  5. soumen1321042
    Cupcake Oct 3, 2019
    tnq, you are really helpful
  6. shresthaB
    Cupcake Dec 15, 2019
    shresthaB , Dec 15, 2019 :
    I am also having this weird lens flare on my oneplus 7 pro. I have attached the photo here. It does not look normal. I have not noticed this type of lens flare from other phones.
  7. Hiteish Sharma
    Eclair Jan 7, 2020
    Hiteish Sharma , Jan 7, 2020 :
    Honestly, the same crap is happening with my phone as well. O thought only my OP7 Pro's Camera is acting weird. How to get this resolved though?
