66
Less is more, the story behind the Bullets Wireless Z’s design
  1. JustASoftwareEngineer
    Ice Cream Sandwich Jun 16, 2020
    JustASoftwareEngineer , Jun 16, 2020 :
    And what happens when you press and hold the volume up and down simultaneously for 3 seconds [Factory Reset]?
    #61
  2. Q1577208613837
    Cupcake Jun 16, 2020
    Q1577208613837 , Jun 16, 2020 :
    I didn't try that. Let me check.
    #62
  3. JustASoftwareEngineer
    #63
  4. JustASoftwareEngineer
    I just tried the song-changing, and it works with my OnePlus 8 Pro, and with my Windows 10 laptop.. Does song changing functionality work when you use other bluetooth headsets?
    #64
  5. sameer_yadav
    sameer_yadav , Jun 16, 2020 :
    i tried to factory reset it holding both volume buttons but nothing happen
    #65
  6. Q1577208613837
    Yes. It used to work with my previous headset.
    #66
  7. JustASoftwareEngineer
    Which button are you pressing when you try and pair your phone? You need to hold the shortcut/switchover button (the only button on the part with the female USB C port) for three seconds, and than the light should begin flashing indicating you're good to pair.
    #67
  8. JustASoftwareEngineer
    Do you have a headset you can pair with bluetooth right now, to see if it works, to isolate whether it's a software configuration issue on your phone, or if it's an issue with your Bullets Wireless Z's?
    #68
  9. Q1577208613837
    Not right now but I'll try it. Thanks
    #69
    JustASoftwareEngineer likes this.
  10. sameer_yadav
    thanks for your consideration but i have tried everything thing which is on Community , YouTube , customer support but the The LED won't even blinked a single time. i tried to put on charge but still the same white colour
    #70
  11. JustASoftwareEngineer
    Definitely odd that when you magnetically clasp the buds together, it still keeps the light on. Have you considered letting it run out of battery?
    #71
  12. sameer_yadav
    yup... i am waiting for it to drain completely. i think the battery will last couple of days its already been 5 days it seems like it's almost over..
    #72
  13. K Hemanth Kumar
    Eclair Jun 16, 2020
    #73
  14. Q1570545915805
    #74
  15. Tanziralam
    Cupcake Jun 17, 2020
    Tanziralam , Jun 17, 2020 :
    I have recently bought one plus wireless 2 , after using 1 week i noticed that in left side hearing lower sound. How can i fix it ???
    #75
  16. sameer_yadav
    sameer_yadav , Jun 17, 2020 :
    i have the same problem for last 6 days today finally its battery got completely drain i put it in charge and it started working again...
    #76
  17. F1592331073633
    #77
  18. G1575050334846
    #78
  19. HonestSavage
    Gingerbread Jun 17, 2020
    #79
  20. HonestSavage
    HonestSavage , Jun 17, 2020 :
    how much time does it takes to charge 0-100% from a 20W Dash charger ? (Mine surely doesn't show white light after 20-30mins but after 45mins )
    #80
