66
Less is more, the story behind the Bullets Wireless Z’s design
  1. Sadik Sayyed
    Cupcake Jun 17, 2020
    #81
  2. Antony Roy
    Cupcake Jun 18, 2020
    Antony Roy , via OnePlus 6 , Jun 18, 2020 :
    Oneplus earphones are comparatively of a flatter signature. Hence so. Also , Oneplus earphones offer much better clarity and crisp details than any of the brands you mentioned above. If you have visited local tech stores , you probably would have seen cheap speakers that go dancing about due to their bass. That is cheap sound quality and you'll probably end up with a headache if you use them. TRY USING the old apple earphones that come with a wire. They have bass , but if you compare them to a BOAT you ll still think the boats are better.
    SOUND QUALITY IS NOT JUST ABOUT BASS
    #82
  3. Antony Roy
    Yes, It does take about an hour and fifteen minutes . I own a Oneplus 6 and it takes anywhere between 60 and 75 minutes
    #83
  4. Jonathan M.
    #84
  5. I1562869506998
    Gingerbread Jun 18, 2020
    #85
  6. I1562869506998
    I1562869506998 , via OnePlus 7 Pro , Jun 18, 2020 :
    ok thanks..
    #86
  7. #87
  8. Hari_Karthick
    #88
  9. dany0602
    Eclair Jun 18, 2020
  10. AbhishekThote
    #90
    Shanmu1212 likes this.
  11. nitinnb02
    nitinnb02 , via OnePlus 6T , Jun 18, 2020 :
    you use real me and check the OnePlus z it's not of good bass. bass also matters in music .
    #91
  12. Antony Roy
    I agree bro , I just said music is not all about bass. Maybe the bass is better on the real me but it does not offer the clarity and crisp details that the Oneplus z does. overall my opinion is that the Oneplus Z is a better package. Also considering the better battery life and fast charging .
    #92
  13. NathanOc
    #93
  14. Shanmu1212
    Shanmu1212 , via OnePlus 6 , Jun 18, 2020 :
    Hi
    Today only I got BWZ ..for my one plus 6..after paired with my phone.
    while incoming call coming means in headset it not telling any notification or caller Id (Full Silent mode).
    Is there any option to change?
    please kindly give solution.
    #94
  15. HonestSavage
    #95
  16. Z1580524954164
    #96
  17. SaiKumarNarla
    SaiKumarNarla , via OnePlus 7 , Jun 18, 2020 :
    i have recieved the earphones yesterday , i have observed the microphone is over sensitive it picks all the background noise where its impossible for other person to hear my voice, is this only happening with my piece or anyone encounter with the same issue, help me should i change to other product or other brand.
    #97
    G_Roshni_Sharma_UABt likes this.
  18. T1592550024116
    Cupcake Jun 19, 2020
    #98
  19. #99
  20. G_Roshni_Sharma_UABt , via OnePlus 7T , Jun 19, 2020 :
    same here! idk if it can be returned
