66
Less is more, the story behind the Bullets Wireless Z’s design
  1. Akhil Reddy.D
    Cupcake Jun 19, 2020
  2. Ketanshinde45
  3. I1562869506998
    Gingerbread Jun 20, 2020
    I1562869506998 , via OnePlus 7 Pro , Jun 20, 2020 :
    Same problem with me almost more than 1 week.. i asked for solution by mail and other groups ..but no responce..
    K1594170121691 likes this.
  4. I1562869506998
    U did any special effort to drain batteey.. coz here more than 1 week and seems same..
  5. HonestSavage
    HonestSavage , Jun 20, 2020 :
    Just curious can you take a shower with these ? i lowkey wanna do that but idk if they will survive
  6. Drunk_af
    Eclair Jun 21, 2020
    Drunk_af , via OnePlus 5T , Jun 21, 2020 :
    Sure they are
  7. O1589563262735 , via OnePlus 8 Pro , Jun 21, 2020 :
    Price is unbelievable. Comfort not as much. Whenever I need to adjust the position of the earbuds, it just feels really strange . So long as your expectations are realistic, it does its job. Just don't expect it to perform better than headphones that costs 2 or 3x more.
  8. BJain21
    Donut Jun 21, 2020
    BJain21 , via OnePlus 6T , Jun 21, 2020 :
    I'm experiencing alot of latency on these earphones. There is no difference after turning on Fnatic mode either. Can you please fix these issues or should I opt for a replacement.
    Nilambarn likes this.
  9. A1592202678431 , via OnePlus Community App , Jun 21, 2020 :
    I am buy one plus bullets z but inside the box i have no logo of never settle so pleas answer me my one plus bullets z is original ya duplicate ?
  10. A1592202678431 , via OnePlus Community App , Jun 21, 2020 :
    any body is face that issu pleas help me i ordered one plus bullets wireless z 16/6/20 and my package was delivered in 18/6/20 so i shocked for this fast delivery but i watched inside the box no never settle logo in the box so pleas tell me every if any body face that issu so what the next our one plus bullets z is original ya duplicate pleas help me
  11. lugatta77
    Cupcake Jun 21, 2020
  12. srvsethi11
  13. Burhanshera
    Cupcake Jun 22, 2020
    Burhanshera , via OnePlus 6 , Jun 22, 2020 :
    Please help me with an issue with the Oneplus z earphones. It has started beeping abruptly without any cause.. have to press the middle button to stop the beeping sound. it was working fine. But started to beep again and again even after pairing again. why is it happening need a fix asap. Thankyou.
  14. akki_9580
    Donut Jun 22, 2020
    akki_9580 , via OnePlus 6T , Jun 22, 2020 :
    Burhanshera
    Please help me with an issue with the Oneplus z earphones. It has started beeping abruptly without any cause.. have to press the middle button to stop the beeping sound. it was working fine. But started to beep again and again even after pairing again. why is it happening need a fix asap. Thankyou.​
    Maybe you can try to factory reset the earphones (Press Volume up and volume down buttons simultaneously for 3 seconds) and try connecting them to your device after that.
  15. Burhanshera
    Doesn't help. Did try to reset it again but didnt help at all. the beeps go on and on. and the volume goes up and the beeps go on and on. have to press the middle button to stop the beeps. its so annoying. Have been continuously using one plus earphones since last 4 years now. this is the first time its being so annoying all these beeps.
  16. akki_9580
    Donut Jun 22, 2020
    Okay, now this sounds childish but just give it a try - Separate both the earbuds and leave it as it is so that the earphones' battery drains down to 0%. Then try recharging the earphone followed by a factory reset. Then try and connect it to the device. I know that sounds weird but then you can try it if you want. Maybe it helps ;)
  17. love@prz
  18. Saif_Shakeel
  19. Burhanshera
    Cupcake Jun 23, 2020
    Burhanshera , via OnePlus 6 , Jun 23, 2020 :
    I shall give this a shot. but seems the volume up and the middle one doesnt work that way !
  20. Vkamat1990
    Vkamat1990 , via OnePlus 6 , Jun 23, 2020 :
    For reset the Bwz hold the volume up and down at same time 2 to 3 sec light will be blink the product will be as new
