3
let's remove the audio jack [Devil's Advocate] hypothetical
  1. lostLambda
    Lollipop May 20, 2017
    lostLambda , May 20, 2017 :
    Tell me about it. I hate listening to streamed BT music. Sounds like plastic.
    #61
  2. elanglois
    elanglois , May 20, 2017 :
    APTX is supported with root, and I think in latest open betas. However, it's still lossy compression. It's better than older protocols, but still lossy, so we agree.
    And the cost of the jack isn't the issue as much as the space I think.
    #62
  3. luismasg
    Eclair May 21, 2017
    luismasg , May 21, 2017 :
    Great! thank you.
    #63
  4. StinkySocky
    Ice Cream Sandwich May 22, 2017
    StinkySocky , May 22, 2017 :
    "Nitpick." Your whole post was one sentence. It's hard to call questioning the implications of that one sentence "nitpicking." Why is the headphone jack "useless?" It has one of the most clear uses of any part of the phone.
    #64
  5. guanyu210379
    Jelly Bean May 22, 2017
    #65
    lostLambda likes this.
  6. sfomin
    Nougat May 22, 2017
    sfomin , May 22, 2017 :
    it is useless because it hasnt been used even once in the last year, duh [​IMG]
    #66
    malidan likes this.
  7. Never Subtle
    Ice Cream Sandwich May 23, 2017
    Never Subtle , May 23, 2017 :
    The first phone I had with a proper stereo jack was 15 years ago. Shortly afterwards we got bluetooth and I haven't used one since. Jacks for phones should have disappeared with telephone switchboard operators.
    #67
  8. antwan.reynolds
    Eclair May 23, 2017
    antwan.reynolds , May 23, 2017 :
    aptX is a gimmick. aptX HD is where it's at. The almost doubling of the bitrate really helps. Too bad the headphone selection is slim pickings. Production should ramp up with the release of Android O.,
    #68
  9. elanglois
    Lollipop May 23, 2017
    elanglois , May 23, 2017 :
    It's still lossy compression. I don't find the cable to be a problem
    #69
  10. elanglois
    So we can have shitty music and extra batteries in the headphones and huge latencies?
    That little cable is that bad
    #70
  11. antwan.reynolds
    Eclair May 23, 2017
    Who's disputing that? Not I. I'm just saying it's a damn good option for Bluetooth headsets.
    If they release a Bluetooth 5.0 Exclusive codec that's capable of handling a 1.3Mbps lossless audio track without transcoding loss will that suffice?
    As for you, there are USB-C to 3.5 Adapters available. I'm not sure if they work with the 3T.
    #71
  12. elanglois
    I see no reason to ditch the headphone jack. My phone stays within reach, so I see no reason for wireless.
    USB C option is always there, even if they keep the headphone jack. Its not a reason for or against. USB only means you can't easily charge while listening but it makes waterproofing easier
    #72
  13. antwan.reynolds
    Eclair May 23, 2017
    Lol! Don't fret sir as we get "a days power in half an hour."
    #73
  14. aris
    Jelly Bean May 23, 2017
    #74
  15. StinkySocky
    StinkySocky , May 23, 2017 :
    I use it at least once every other day. It's also nice to have a uniform, wired solution that I can use when my phone is plugged into a battery bank.
    #75
  16. Two
    Honeycomb May 24, 2017
    Two , May 24, 2017 :
    How exactly do you add AptX support just by having your phone rooted? Or is there a zip to flash I don't know about?
    #76
  17. elanglois
    Lollipop May 24, 2017
    elanglois , May 24, 2017 :
    There are probably many methods. What you want to do is get the aptx library onto your system partition. That requires root and you can no longer OTA.
    Easiest method is using Magisk to root (since it hides root and allows Pay and Snapchat to work) and then you just use the Magisk app to find and install the AptX Magisk Module, then reboot.
    #77
  18. Two
    I found a way in XDA: https://forum.xda-developers.com/oneplus-3/themes/mod-aptx-codec-t3521228
    Just have to flash a few zip.
    Thanks because I thought it may never come!
    #78
  19. saedawke
    Cupcake May 24, 2017
    saedawke , May 24, 2017 :
    Here in my location every number starts with 0 (Zero), and my new onePlus 3T is removing leading zeros every time i tried to get back to my history of dailing numbers, it myst be to edit every time I making a call back
    #79
