87
Let’s talk about Portrait Mode.
  1. magnusenorson Cupcake Dec 7, 2017
    magnusenorson, Dec 7, 2017 :
    i wasn't asking why, i was complaining about how poorly implemented portrait mode is - since the algorithm demands so much more light than the sensor lets in most of the time.
  2. biswasprasenjit Eclair Dec 7, 2017
  3. biswasprasenjit Eclair Dec 7, 2017
    biswasprasenjit, Dec 7, 2017 :
    spelling mistake...its "if"
  4. Q1511627292000 Cupcake Dec 7, 2017
    Q1511627292000, Dec 7, 2017 :
    Why can't we take portrait pictures in low light conditions ? i believe u guys will give this option too in the next update !! [e]1f60a[/e]
  5. rajsanand Eclair Dec 7, 2017
    rajsanand, Dec 7, 2017 :
    Why can't we have post-processing in the portrait mode.
    I Had it in my Lenevo Phab 2 Plus but it was really bad. THe 10.Or G is much better at post processing and you can blur of the background a lot more if you want to.
    If Oneplus introduces this and perfect it like make the software really treat the background as a separate image(Phab 2 Plus was more like Bokeh effect software if you choose too much blur it would even blur the edges of the front object, but 10.OR G didnt do that as much ) then the camera would rock.
  6. Y1511446669413 Honeycomb Dec 7, 2017
  7. biswasprasenjit Eclair Dec 7, 2017
    lets not talk about it... you have marketed and also printed in the box that this a best camera phone...but sadly its not a breakthrough for oneplus..ur own brands like oppo n vivo are already rulling in camera segment n they have way better picture than 5 or 5t
  8. mauleethorat Eclair Dec 8, 2017
    mauleethorat, Dec 8, 2017 :
    Please add theme/wallpaper/ringtone store in OP devices
  9. MURALI_M. Praveen Cupcake Dec 8, 2017
  10. ijtaba7 Froyo Dec 8, 2017
    ijtaba7, Dec 8, 2017 :
    Depends on what you refer to as 'noise'. Technically, noise in photography occurs because of lack of light and increased sensor gain (increased ISO). While the OIS reduces the blurr (unwanted shaky motion) which occurs due to camera/hand shake at slow shutter speeds. So the lack of OIS is mostly the problem for "handheld" low light photography only!
    In day timing, specially outside in sunlight, OIS isn't even needed when you get the shutter speeds as fast as 1/2000-8000.
  11. OOTPApps Gingerbread Dec 8, 2017
    OOTPApps, Dec 8, 2017 :
    Fix camera quality and there's virtually zero reason to not recommend the OnePlus lineup to everyone!
    Please start by fixing the 3/3T so it can live it's full potential!
  12. Koolvini Donut Dec 8, 2017
  13. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 8, 2017
    NeVeR_SeTTLe, Dec 8, 2017 :
    The OnePlus 5T has a 1.7 aperture, which has more light taken in then my OnePlus 3T. OIS is on the 3/3T and they produce me clearer photos than the 5/5T in low light. The OIS is a must if your hands shake but also to reduce some noise in the background. I'm not saying that this only contributes to noise... Other factors like camera software, algorithms, etc also have a huge affect on noise, but OIS is also a part of it.
  14. ijtaba7 Froyo Dec 8, 2017
    OIS doesn't reduce noise. The only thing which OIS does is that it reduces motion blur by compensating for the motion (if there's any). Noise in images appears because of lack of light and increased ISO.
    Presence and absence of OIS won't affect the noise in your pictures as OIS is a separate mechanical part while the production of noise is related to the image sensor itself.
    Google “Image noise” for further study.
  15. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Dec 8, 2017
    Attaching screenshot
  16. G_Tanveer_Ansari_wgeD Eclair Dec 8, 2017
    G_Tanveer_Ansari_wgeD, Dec 8, 2017 :
    tbh. portrait mode in my OP5 is good but not so perfect. and we also dont have live adjustments of the blur like we have in note 8.
  17. Subhodip Routh Cupcake Dec 9, 2017
  18. F_Anthony_Micheal_Exge Froyo Dec 9, 2017
    F_Anthony_Micheal_Exge, Dec 9, 2017 :
    no doubt all feature of op5 are awesome but i wish i could get same features in selfie mode also like iPhone x.
    will be waiting for your response.
    thanks
  19. Cyandroid95 Donut Dec 9, 2017
    Cyandroid95, Dec 9, 2017 :
    OP5 and OP5T are almost the same, Like S7 and S7 Edge.. there is no excuse
    K1512835740776 likes this.
  20. dsmonteiro The Lab - OnePlus 5T Reviewer Community Expert Dec 9, 2017
    dsmonteiro, Dec 9, 2017 :
    No excuse for? I'm not following.
    Why would they actively advertise a discontinued device?
