7
Let's try to understand bugs in ota 4.0.2
  1. cmitchellshaw
    KitKat Feb 3, 2017
    cmitchellshaw , Feb 3, 2017 :
    did you do either a cache wipe or a full wipe?
    Pinttas likes this.
  2. cmitchellshaw
    KitKat Feb 3, 2017
    call your carrier and ask what APN setting to use.
    Pinttas likes this.
  3. G_aayush_pandey_vxCA
    Froyo Feb 3, 2017
    G_aayush_pandey_vxCA , Feb 3, 2017 :
    as a matter of fact i did use the canada vpn but did not face any issues after the 7.0 update... not even a single problem. I DID NOT EVEN HAD TO CLEAN WIPE THE FONE
    Pinttas likes this.
  4. cmitchellshaw
    KitKat Feb 3, 2017
    "autonomy"
    you keep using that word, but I do not think it means what you think it means...
    Pinttas likes this.
  5. Pinttas
    Honeycomb Feb 3, 2017
    Pinttas , Feb 3, 2017 :
    ... then you should not have f2fs data but you probably do not need it.
  6. Pinttas
    Battery life
    PS. Thanks
  7. gabrikrm
    Cupcake Feb 3, 2017
  8. Pinttas
    I didn't understand the issue very well, but the photos are sorted by date in the gallery.
  9. G_Athithan_L_TXrW
    Eclair Feb 3, 2017
    G_Athithan_L_TXrW , Feb 3, 2017 :
    People, bugs are universal among a set of devices running the same software. a corrupted install is a stupid argument that cant be termed bug but a crash and crc will fail install. grow up!
    When someone reports bug and another claims it isn't then one of them dont understand the problem! Either you didn't listen to the bug reporter or the reporter misread the feature/limitation as a bug.
    Baseline is to understand the people with trouble to help them and stop harassing/teasing/bullying. Communities are to help not to abuse!
    Thanks!
  10. Pinttas
    Hard reset, wipe data and cache in recovery, installation by adb ... can be considered a complement to the update process and has helped eliminate many bugs.
    In this way, the one plus team does not try to solve bugs that are possibly not bugs.
    Obviously hard reset,... does not solve all the bugs but it has helped a lot.
    What is not solved in this way counts on the help of those who had the same problem and solve it and with the help of the most knowledgeable.
    So we need and appreciate your help.
  11. Irfan Chasmawala
    Donut Feb 4, 2017
  12. Harry_Broom
    Froyo Feb 4, 2017
    Harry_Broom , Feb 4, 2017 :
    is this on your home connection or on everything?
    if your home & your hub is AC (2.4ghz & 5 ghz) there maybe an issue with the chipset especially if using the Atheron one. sometimes if you create a separate SSID for the 5 ghz & maybe use a different channel to the 2.4 then it can fix this issue.
    Pinttas likes this.
  13. Pinttas
    Honeycomb Feb 4, 2017
    Pinttas , Feb 4, 2017 :
    Good tip harry_broom. I hope it works out. However this is an improvement point recognized by oneplus.
    https://forums.oneplus.net/threads/oxygenos-4-0-2-n-ota-for-oneplus-3.489599/
  14. Pinttas
    Since this day the widget has not disappeared! I did nothing, just rebooted the smartphone after changing the dpi to the standard size
  15. dgonzalez2313
    Froyo Feb 4, 2017
    dgonzalez2313 , Feb 4, 2017 :
    those with bugs should hard reset their phones. I had some bugs and did that and it worked like a charm my battery last a looooooong time now before it was dying before the end of the day. make sure you back everything up first though.
    Pinttas likes this.
  16. Pinttas
    Thats the point friend.
    Thanks for your feedback
  17. Jayadheer Chitta
    Donut Feb 4, 2017
    Jayadheer Chitta , Feb 4, 2017 :
    initially even i had many problems with the new update from oneplus, later i formatted my phone and most of the problems are solved.
    try using the same technique, it even worked with my WiFi dropping issue.
    Pinttas likes this.
  18. shakilur0128
    Eclair Feb 4, 2017
  19. kartikeyainfo52
    Cupcake Feb 4, 2017
    Pinttas likes this.
  20. Pinttas
    Have you tried clearing the cache and data in the playstore application?
    shakilur0128 likes this.
