2
LG G4 or OP2?
Op2 or lg g4
Poll closed Aug 8, 2015.
  1. Op2
    54.3%
  2. Lg g4
    45.7%
  1. mrbearbear
    Ice Cream Sandwich Jul 29, 2015
  2. carlosfilippsen
  3. The _Great_Uniter
    Cupcake Jul 29, 2015
    The _Great_Uniter , Jul 29, 2015 :
    The LG G4 doesn't have a fingerprint scanner and tends to lag from what I've heard. While the 1+2 doesn't have a removable battery or expandable storage, I will never need more than 64gb and I have never done and on-the-go battery swap with my Galaxy S4. Thus lacking that functionality isn't that big of a deal for me. When you put all of that together wit the price point of the 1+2 vs the G4, with my limited budget, the 1+2 wins out by far.
  4. aenews
    KitKat Jul 29, 2015
    aenews , Jul 29, 2015 :
    Thanks for the recommendation, just watched the video. The Snapdragon 808 just has less cores than the 810. There isn't anything more efficient about it. If you just manage the cores on the 810 better to control heat then it's a much better SoC (Which OnePlus has promised to deliver... we shall see). AnTuTu is not that reliable a benchmark. It is much easier to see what's going on if you compare Geekbench/GFXBench Scores. Geekbench scores are around the same while GFXBench is highly in favor of the Snapdragon 810 owing to the Adreno 430. Yes, obviously with severe throttling, optimal performance no longer matters, but my point is that there is nothing about the Snapdragon 808 that makes it less heat-prone other than the fact that it is a worse SoC. If you just disable two of the high-end cores on the S810, it will perform better than the S808 hands-down. So I would expect that OnePlus did what it takes to manage the heat given the controversy, and they claim as much at the moment.
  5. bigjohnsta
    Honeycomb Jul 31, 2015
    TrevinD, jay ray, SachinA and 5 others like this.
  6. Nixudos
    Froyo Jul 31, 2015
  7. SammyNib
    Gingerbread Jul 31, 2015
    SammyNib , Jul 31, 2015 :
    Damn, I was hoping for a speed comparison, all this video does is outline the specs of each device!
    naseem95 likes this.
  8. alphaplus
  9. funmunke
    Marshmallow Jul 31, 2015
  10. naseem95
    naseem95 , Jul 31, 2015 :
    Yeah this video isn't much use till they make their full comparison video
    TrevinD likes this.
  11. EpicSwirly
    Jul 31, 2015
  12. Serco
    Ice Cream Sandwich Jul 31, 2015
    Serco , Jul 31, 2015 :
    The real review for me will be the one, real users will post here on the forum when they will have it on hands after August 11th. ;)
    shekar163 likes this.
  13. bigjohnsta
    bigjohnsta , Jul 31, 2015 :
    Correct, posted by Android Authority. I should've mentioned it's a "Quick Look" not a technical full review.
    Deactivated User likes this.
  14. Serco
    It is a really QUICK LOOK. I could read the spec sheet by myself!!!!
  15. mopsert
    KitKat Jul 31, 2015
  16. SonamKapadia
    SonamKapadia , Jul 31, 2015 :
    I like it that the OPT has better brightness and viewing angels. When you use a phone on a golf course in the afternoon, the value of this apparent.
  17. 1+1=11!
    1+1=11! , Jul 31, 2015 :
    I love the the design of the opt much more but the camera app of the g4 looks awesome with all the settings
  18. SachinA
    Donut Aug 1, 2015
  19. Nevabackdown
    Jelly Bean Aug 1, 2015
    me.ayush027 likes this.
  20. nilrb
