Display light sensor
  1. ascrounch
    Donut Feb 28, 2020
    ascrounch , Feb 28, 2020 :
    hello, I find the light sensor very slow. it often takes more than 3 seconds to realize that the light has changed and therefore takes time to increase or decrease the brightness of the screen. I think it is a bad fit rather than a hardware problem. could you change that? it's really annoying on a daily basis. ps: I formatted the phone and cleaned the sensor.
  2. drl431
    Marshmallow Feb 28, 2020
    drl431 , Feb 28, 2020 :
    Hi, the timing of the adaptive brightness function is probably baked in the Android OS. But do you really want screen brightness to change with momentary movement of the phone or with a brief shadow? Like with anything, there will always be some people that want it different. Myself, I don't use adaptive brightness in low light situations, like at home. Everywhere else, it works pretty good.
    Caomhin likes this.
