5
lineage 14.1 vs Oxygen 3.5.8
  1. rickybarretto
    Gingerbread May 20, 2017
    rickybarretto , May 20, 2017 :
    I have mentioned the advantages of the ROM below
    lineage (no root):
    better standby
    less heating
    pixel launcher looks and feels good
    split screen
    reply from notification panel
    OOS 3.5.8:
    3 finger screenshot
    better camera
    dark UI
    quick notes in shelf
    my experience is based on completely stock lineageos official rom. will try camera mods and Franco kernel next week.
    feel free to ask your questions and I'll try answering them as quickly as possible.
  2. rickybarretto
  3. Bauwuau
    Donut May 20, 2017
    F_Omkar_Khandare_vpsW likes this.
  4. Aureatron
    Aureatron , May 20, 2017 :
    I'm on Lineage since 2 months now.
    On stock LOS kernel + Opengapps Aroma with no google dialer and other crap (Google dialer requires the dialer framework which breaks network in our LOS builds), battery life is good (I prefer performance over battery), UI and Gaming performance is much better than what I experienced on OOS 3.5.8. It is very stable, never faced a reboot or crash. Camera Quality is Okay, I'm using the OOS camera port and it works really good. You won't be able to save images as RAW files but I never used it anyways. It's nougat and I'm really addicted to those sweet features like split screen and quick replies, I don't think I'll switch back to OOS.
  5. Saurabh_221
    Ice Cream Sandwich May 20, 2017
    Saurabh_221 , May 20, 2017 :
    On oneplus 2? are you crazy...? look at thread section and also the thread title....4.1.x not yet released for oneplus 2
    Arun Nassy, Miratek, tbalnt and 5 others like this.
  6. tadydrift
    Honeycomb May 21, 2017
    Miratek and Bauwuau like this.
  7. tusar8
    Jelly Bean May 21, 2017
    tusar8 , May 21, 2017 :
    Resurrection Remix
    Pros
    More stable than Lineage as the team has improved the OS better than Lineage.
    Fluid and Smooth
    Awesome battery life Using Franco kernel+manager, naptime and greenify
    Cons
    Camera app
    Best alternative (bacon camera, freedcam and camera x)
    7 hrs SOT without gaming and 4 hrs with gaming
    d1beats and bcshiguemichi like this.
  8. bcshiguemichi
    Eclair May 21, 2017
    bcshiguemichi , May 21, 2017 :
    loving RR.
    camera is not the best so I flashed the OnePlus 3T camera - working like a charm!
    I can't get the same battery as you (tried the same configuration you mention, and a lot of other similar apps - servicely, forcedoze, naptime, greenify, etc.
    any other tip?
    rickybarretto likes this.
  9. user 7
    Ice Cream Sandwich May 21, 2017
    user 7 , May 21, 2017 :
    even resurrection has 3finger screenshot option and oos camera is compatible...
    It is compatible with substratum and using oxygen theme ,you won't feel a difference.
    its the best
    tadydrift and rickybarretto like this.
  10. tusar8
    Tried that camera app. It lacks quality. The max file size was 4mb and it does not have RAW capture. So i'm using Bacon camera, images land in between 7-12 mb and it has both manual and raw capture.
  11. hmuny99
    Gingerbread May 21, 2017
    hmuny99 , May 21, 2017 :
    Are you using the official or the non-official one?
  12. d1beats
    d1beats , May 21, 2017 :
    Gonna add it to multirom today. Been using oxygen for the longest with boeffla kernal and I've never had any problems. Time to try lineage I guess
  13. tusar8
    Official.
  14. innis.neil
    pankaj1004, ehsaanbhati and Bauwuau like this.
  15. innis.neil
    innis.neil , May 21, 2017 :
    I guess I should go back to Oxygen and flash Boeffla Kernel.... Probably by next week or so.
    Thanks for your feedback.
  16. M4Master
    Honeycomb May 22, 2017
    M4Master , May 22, 2017 :
    You can get the stock OOS camera ported to lineageos from this xda thread :)
    https://forum.xda-developers.com/oneplus-2/themes-apps/oos-3-0-beta-camera-cm-13-t3350060
    what's your SOT ?
    i am using Boeffla kernel and i get around 5 hrs without greenify and naptime
  17. tusar8
    Jelly Bean May 22, 2017
  18. M4Master
    I was asking you to test your SOT without enabling greenify and naptime....
    with those, 7+ hrs is awesome...
    just wanted to know SOT of RR with Franco
  19. OAA
    Cupcake May 22, 2017
  20. tusar8
    tusar8 , May 22, 2017 :
    Oh. With stock kernel only 4 hrs. With only franco 5 hrs.
    With franco kernel+manager, greenify, naptime and without gaming 7 hrs.
    But it all depends on the user usage.
    SankalpJa, rickybarretto and M4Master like this.
