10
Lineage OS 14.1 [Nougat 7.1] for Oneplus 2 (cm14.1 continuation)
  1. ShortyEx
    Ice Cream Sandwich Feb 26, 2017
    ShortyEx , Feb 26, 2017 :
    The official lineageOS thread in this subforum has a lot of people with this complaint sharing their experiences. At this point I believe the best thing to do is restore to the previous build if you have a backup
    #41
  2. Taifur
    Froyo Mar 22, 2017
    #42
    Ashrafuli353 likes this.
  3. ijus_amazing
    Gingerbread Mar 23, 2017
    ijus_amazing , Mar 23, 2017 :
    where is it? i'm trying to find it. help please...
    #43
  4. semaj81
    Donut Apr 18, 2017
    semaj81 , Apr 18, 2017 :
    It's in the notification settings... the cog at the top right.
    #44
  5. vijayvk84
    Honeycomb Apr 21, 2017
    vijayvk84 , Apr 21, 2017 :
    Post some screen shots pls...........
    Even I am planning to upgrade to Linage OS as I am tired of waiting for official Nougat update from OP
    #45
  6. Narenat94
    Cupcake Apr 22, 2017
    Narenat94 , Apr 22, 2017 :
    I have tried Lineage OS, Tesla and Cosmic OS(all flashed in mentioned order after a month's use) and haven't used OOS in a very long time. The last build i was in was 3.0.2 and VOLTE wasn't a need for me then, but for me to use it now i need to flash 3.5.6 where VOLTE was added.
    It would be helpful if anyone could tell me whether to flash OOS or not since there have been issues noted in them. I plan to go back to Lineage OS with VOLTE, So should i risk flashing OOS for VOLTE or is there another way?
    Thank you people.
    #46
  7. Narenat94
    Cupcake Apr 28, 2017
    Narenat94 , Apr 28, 2017 :
    Anybody?
    #47
  8. ShortyEx
    Ice Cream Sandwich Apr 28, 2017
    ShortyEx , Apr 28, 2017 :
    LOS has the OOS3.5.8 sources merged into it since the official weekly build they released yesterday.
    I would recommend you to follow the dedicated thread about it in this section of the forums and see what people have to say about it in the following days, if it's good then I see no problem in making the move.
    I can't say if VoLTE works properly but I suppose it does. I live in a region where VoLTE is not enabled or needed so I can't give you any solid info on that, but I bet someone in the dedicated thread will be able to tell you :)
    #48
    Narenat94 likes this.
  9. WSP{PgDn
    Cupcake May 4, 2017
    WSP{PgDn , May 4, 2017 :
    [QUOTE =“mhdathiq,post:15548877,member:809707”] [ATTACH = full] 478557 [/ ATTACH]
    The Oneplus 2是由Cyanogenmod开启的官方夜生活关闭之后,首先被添加到血统发展的构建列表中的装置之一。
    我不是这个rom的开发者,我只是分享这个线程给别人,以获得最大的(cm)现在的Lineage操作系统。
    建造由“ 达克塔克维护
    Rom链接:
    https://androidfilehost.com/?w=files&flid=91603&sort_by=date&sort_dir=DESC
    有关闪烁的更多信息:
    http://www.cyanogenmods.org/forums/topic/oneplus-2-lineage-14-1-nougat-7-1-rom/
    Flash-o-holics开始尝试..我已经使用它从过去3-4天...完全稳定,就像最新的cm 14.1构建..没有主要问题...来自OO 3.5.5和电池也是好的,罗马是稳定的,没有问题.. [/ QUOTE]Did you save this ROM ? Can you send it to my E-mail ?wsp18387176187@gmail.com Thanks.
    #49
  10. J.Nogueira
    Honeycomb Jun 6, 2017
    J.Nogueira , Jun 6, 2017 :
    Hi Guys,
    I am thinking about flashing the new LineageOS nightly from 1st of June abandoning the OOS following the announcement that OP will not release Nougat update (trust level of OP is now 0 after breaking a promise).
    Can someone that is using LineageOS share what is working, what is not and problems that are still present on this build? Is VoLTE working considering that the kernel is coming from OOS 3.5.8?
    Just want to avoid flashing and then realize that is not yet working as expected.
    Cheers all and thanks
    #50
    tadydrift likes this.
  11. ShortyEx
    Ice Cream Sandwich Jun 6, 2017
    ShortyEx , Jun 6, 2017 :
    You can follow experiences in this thread, the last few pages will be the most relevant if you want to know what the current issues are.
    #51
    J.Nogueira likes this.
  12. vrc007
    Gingerbread Jun 16, 2017
    vrc007 , Jun 16, 2017 :
    Was using OOS before and today thought to flash lineage OS.
    Problem I am facing is, Google camera crashes and the stock OOS camera I flashed from here : OP3 Camera 1.4.0 v3.4.zip
    https://forum.xda-developers.com/one...cm-13-t3350060
    Shows blank screen.
    Any solution?
    Lineage OS am using is the latest one : 15062017
    And Gapps : stock.
    Need OOS camera as it's great for OP2.
    #52
  13. jochemjorik
    Froyo Jun 17, 2017
    #53
