48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. ZPasha
    Eclair Dec 23, 2016
    ZPasha , Dec 23, 2016 :
    Hi. Great ROM! I love it! I don't know if it's an issue with WhatsApp or the ROM but if more than one text is sent by the same contact only the latest text is visible in the notification shade and lockscreen. The previous texts aren't visible like how they were in marshmallow. Thanks. Hope I was able to explain the problem properly.
  2. jhalayashraj
    Honeycomb Dec 24, 2016
    jhalayashraj , Dec 24, 2016 :
    That's in CM's hand.
    liskofinal likes this.
  3. jhalayashraj
    Yup That's not ROM issue it's WhatsApp.
  4. jhalayashraj
    Mine works fine I'm using WhatsApp beta.
  5. ZPasha
    Eclair Dec 24, 2016
    ZPasha , Dec 24, 2016 :
    Try turning on run in background option in privacy guard in settings.
  6. liskofinal
    Cupcake Dec 24, 2016
    liskofinal , Dec 24, 2016 :
    And what about the version info when installing/upgrading an app? Would you consider implementing it in the near future?
  7. jhalayashraj
    in future maybe not now.
  8. adi_daga
    Gingerbread Dec 25, 2016
    adi_daga , Dec 25, 2016 :
    What are the new features in next update nd ETA for next update? ;)
    PS : legend 8.0 is stable nd buttery..best 7.0 ROM .. Big thumbs up
  9. luukbernardes
    se7enlyn likes this.
  10. se7enlyn
    Ice Cream Sandwich Dec 25, 2016
    se7enlyn , Dec 25, 2016 :
    I know it works with Private
  11. G_PRAKHAR_GARG_jKtX
    Donut Dec 25, 2016
  12. niTe_RiDeR_Pro
    niTe_RiDeR_Pro , Dec 25, 2016 :
    @jhalayashraj
    A few quesions, please:
    Could you please list out (if any) what functions are not working in this ROM (e.g. Bluetooth, 4G, NFC etc) ?
    Any known bugs?
    Is it stable to use as a daily driver?
    Is mobile data & calling (the modem NON-HLOS.bin) stable enough (as stable as COS)? Thanks.
  13. niTe_RiDeR_Pro
  14. mavhia
    Cupcake Dec 25, 2016
    mavhia , Dec 25, 2016 :
    it is ok for installing new version with dirty install?
    im using v.5 now.
  15. C0ntroller
    Gingerbread Dec 26, 2016
    C0ntroller , Dec 26, 2016 :
    There is no need to do that. There is currently everything working fine and yes I use it as daily driver and it doesn't fails me. You maybe will encounter a few bugs but you really have to search hard for them. You will not experience any bugs at normal usage.
    Why should mobile data & calling not work? Never heard of this issue in any Nougat ROM. Works fine for me.
    The last time I used COS 13.1 is long ago, don't know how battery was there. Get mostly like 6 hours SoT with no "battery extending" apps.
    niTe_RiDeR_Pro likes this.
  16. ElRobertson
    ElRobertson , Dec 26, 2016 :
    Can totally agree to that!
    To sum it up:
    - No Bugs (using it for about 10 days and didn't found one)
    - great battery life (beter than cm13)
  17. luukbernardes
  18. theblackhole
    Froyo Dec 27, 2016
    theblackhole , Dec 27, 2016 :
    Hello,
    Thanks for this ROM. I'm trying to use it as a secondary ROM with MultiROM but it doesn't launch (not even a bootanimation only the "oneplus logo" boot screen).
    Oneplus One 64GB
    Multirom v33b
    Recovery 2016-04-17
    Kernel with kexec-hardboot patch
    LegendROM : cm-14.1-20161216
    Primary ROM : cm-13.0-20161220-SNAPSHOT
  19. C0ntroller
    Gingerbread Dec 28, 2016
    C0ntroller , Dec 28, 2016 :
    Don't know if Rom or CM (/Lineage) related but Android Beam isn't working (not that anybody would use it) and maybe I'm just an idiot but don't I don't manage it to switch Wi-Fi mode from 2,4 to 5GHz. Just little things if you are bored @jhalayashraj ;)
  20. SpeedbirdMotorcycles
    SpeedbirdMotorcycles , Dec 28, 2016 :
    Android Beam works fine here
