48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. G_Rohan_Patre_hiZT
    Gingerbread Jan 2, 2017
  2. arindam4u
    Froyo Jan 2, 2017
  3. TylorMartino
    Donut Jan 2, 2017
  4. SpeedbirdMotorcycles
    SpeedbirdMotorcycles , Jan 2, 2017 :
    I would even add " Ridiculously Stable Awesomeness !!! "
  5. Sidhucs
    Cupcake Jan 3, 2017
    rkiwtir likes this.
  6. Max.Mar
    Jelly Bean Jan 3, 2017
    Max.Mar , Jan 3, 2017 :
    how is OMS substratum themes working as compare to CMTE. I am only waiting for CMTE to get merged first...then will try it.
  7. C0ntroller
    Gingerbread Jan 4, 2017
    C0ntroller , Jan 4, 2017 :
    In my opinion it is extremly good. You wont notice any difference when you use your phone. The great thing of OMS is that you can select multiple themes and take recources from both (eg. you use a dark theme but you can apply your own spinner). Had no problems until no.
    Max.Mar likes this.
  8. Max.Mar
    Jelly Bean Jan 4, 2017
    Max.Mar , Jan 4, 2017 :
    Thanks mate. Any thing that you wanted to point out to me before flashing.
  9. arnab0207
    Cupcake Jan 4, 2017
  10. G_Rohan_Patre_hiZT
    G_Rohan_Patre_hiZT , Jan 4, 2017 :
    Oxygen OS for OPO is still based on lollipop
    With no future updates
  11. C0ntroller
    Be aware there is no Xposed... But every other thing is working fine smooth :)
    Max.Mar likes this.
  12. Prinze Martin
    Ice Cream Sandwich Jan 4, 2017
    Prinze Martin , Jan 4, 2017 :
    We got the OPX ports of OOS 3.1.4 ;)
  13. Max.Mar
    but I heard the camera performance is below average since no Oxygen blobs.
  14. butaixyz8016
    Honeycomb Jan 5, 2017
  15. G_Rohan_Patre_hiZT
    Gingerbread Jan 5, 2017
    ziepicwaffle likes this.
  16. Prinze Martin
    Ice Cream Sandwich Jan 5, 2017
    Prinze Martin , Jan 5, 2017 :
    It might, The OOS 3.5 versions. No promises though, i guess :p
  17. jhalayashraj
    butaixyz8016 likes this.
  18. jhalayashraj
    jhalayashraj , Jan 5, 2017 :
    In future yes.
    rkiwtir likes this.
  19. Prinze Martin
    Hey @jhalayashraj ! Can you get Oxygen/Hydrogen blobs for camera in this rom ? CM HAL isn't good enough for our device (Just a thought) ! Would be awesome if you can do it ! Cuz no dev has tried to merge Oxygen cam blobs in any other CM based rom
  20. C0ntroller
    C0ntroller , Jan 5, 2017 :
    Never used the O2OS cam so I can't say anything. But I flashed Next Camera and it works great.
