48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. jhalayashraj
    Honeycomb Jan 13, 2017
    jhalayashraj , Jan 13, 2017 :
    i know but that is from lineage now they are messing and rebranding things from cm to lineage but still its not a problem till u can set whatever direction u wanna set if u get the pattern ;)
  2. jhalayashraj
    u can dirty flash.
    SpeedbirdMotorcycles likes this.
  3. rohanpitre
    Eclair Jan 14, 2017
    rohanpitre , Jan 14, 2017 :
    True! Btw awesome ROM. This is the first nougat rom which I've stayed on for more than a week. Just for some reason not getting same SOT as other users. But pretty satisfied anyway. Bravo!
  4. rohanpitre
    Eclair Jan 15, 2017
    rohanpitre , Jan 15, 2017 :
    The "prevent accidental wake up" option gets enabled automatically after rebooting. Not that I have any issues with it, just reporting for your notice.
    luukbernardes likes this.
  5. ElRobertson
    Gingerbread Jan 16, 2017
    ElRobertson , Jan 16, 2017 :
    Blur: The blured and transparent background of notifications is only working on app drawer.
    But with an app opened it just shows the normal dark background...
  6. jhalayashraj
    Honeycomb Jan 17, 2017
    jhalayashraj , Jan 17, 2017 :
    Nop everything works fine it just blur will not work on the coming notifications. But if u swipe back and swipe down again it will work that's the only bug and still blur is experimental.
  7. ElRobertson
    Gingerbread Jan 17, 2017
    ElRobertson , Jan 17, 2017 :
    I've changed the Blur settings to more transparent and now it is working!
    Shame on me :)
    And thank you for this awesome ROM! Really man! :)
    jhalayashraj likes this.
  8. rohanpitre
    Eclair Jan 17, 2017
    rohanpitre , Jan 17, 2017 :
    Just a random question!
    I was using tugapower N rom before this one, and I was getting these amazing charging rates of 1700-1800mA on Ampere. Now this ROM is surely more stable and has way better battery life than that one, but the charging rates are almost half. In fact I never had charging rate of more than 1100mA on any ROM. What can be the reason behind such fast charging rates on tugapower? Can anything be done about it?
  9. G_Rohan_Patre_hiZT
    G_Rohan_Patre_hiZT , Jan 17, 2017 :
    I get a peak of about 1700mA on this ROM
    rohanpitre likes this.
  10. rohanpitre
    Eclair Jan 18, 2017
    rohanpitre , Jan 18, 2017 :
    I don't think it will be fair to compare with others because voltages vary. I get 1100mA max, at times. Mostly it's between 500-700mA.
    Are you using any custom settings, or custom kernel?
  11. jhalayashraj
    Honeycomb Jan 20, 2017
    jhalayashraj , Jan 20, 2017 :
    Don't know what u r saying coz I'm giving fast charging from the first build of LegendROM and other ROMs cherry-picked fast-charging feature from LegendROM. If u r using any custom kernel thn of course fast-charging feature will be removed because of kernel changes.
    G_Rohan_Patre_hiZT likes this.
  12. rohanpitre
    Eclair Jan 20, 2017
    rohanpitre , Jan 20, 2017 :
    On stock kernel itself. I'm not saying the charging speeds are any bad, I've had similar speeds throughout 2 years across different roms on my Oneplus one. Just on tugapower they went to 1800mA. Does having a heavily loaded phone affect charging speed in any way? Because others are getting good speeds!
  13. rsennat
    Donut Jan 21, 2017
    rsennat , Jan 21, 2017 :
    @rohanpitre @jhalayashraj With legendrom 10.0, and default kernel, it takes about 100 mins to charge from 5% to 100%
    it shows 1500mA on an average. max of 1600mA. you need to use the standard charger came along with OPO.
    Recently I tried 4A charger of Moto G4Plus, and in just 45 mins or so almost 90-95% charged from 5%.
    it also depends on what else is running on the device when charging, GPS, LTE, etc.. will slow down charging, as it consumes battery while charging. isn't it?
  14. rsennat
    Donut Jan 21, 2017
  15. ElRobertson
    Gingerbread Jan 21, 2017
  16. adi_daga
  17. jhalayashraj
    Honeycomb Jan 21, 2017
    jhalayashraj , Jan 21, 2017 :
    post your ampere app screenshot while charging.
  18. jhalayashraj
  19. jhalayashraj
    UPDATE:- 11.0
    Changes:-
    • TaskManager Customizations
    • Memory bar
    • Change toast frames color to some better look ones
    • Set the power menu volume selector as green
    • Materialize missed calls icons
    • Improve scrolling cache
    • Speed things up to the max
    • Adjusted animation timing
    • Allow faster app switching
    • Add volume link notification switch
    • Launch default music player on headset connect
    • Lineage boot animation
    • Fixing notification volume stream title
    • Lockscreen charging Formatting improvements
    • Fix FAB not disappearing in multiwindow
    • Fix battery text gap issue
    • FIX No sim airplane mode padding
    • OMS7-N: Apps: show/hide Substratum icon overlays
    • Mark as eligible for Google Assistant
    • Synced with Latest LineageOs
    Download:- https://www.androidfilehost.com/?fid=673368273298925419
    If u guys like my work and have some spare bucks to share please consider a donation.
    Donate to me:- https://www.paypal.me/jhalayashraj
  20. luukbernardes
