48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. C0ntroller
    Gingerbread Jan 28, 2017
    C0ntroller , Jan 28, 2017 :
    Today I learned there is an alarm triggered automatic boot...
    So if this would be working, you would just make an alarm and then turn your phone off?
  2. jhalayashraj
    Honeycomb Jan 28, 2017
    jhalayashraj , Jan 28, 2017 :
    I will improve stock kernel in 12.0 i think now its time to improve battery life enough with the features for now. Till thn flash any custom kernel for better battery life.
  3. jhalayashraj
    Okay this is new thanks for reporting. I will look into it.
  4. jhalayashraj
  5. ElRobertson
    ElRobertson , Jan 28, 2017 :
    yes of course. And it was working in cm13 at least.
    C0ntroller likes this.
  6. C0ntroller
    Never noticed that, thank you ;D
    ElRobertson likes this.
  7. rohanpitre
    Eclair Jan 28, 2017
    rohanpitre , Jan 28, 2017 :
    But do other kernels support the quick charge ? Also, which ones will you recommend ?
    And about the alarm thing, I also did not know that. I set an alarm and switched off my phone. It never started, or tried to.
  8. G_Rohan_Patre_hiZT
    G_Rohan_Patre_hiZT , Jan 28, 2017 :
    you should join the telegram group. You get answers much faster there
  9. jhalayashraj
    well intense-LegendEdition kernel has fast-charging u can try that. don't know about this alarm thing but it must be lineage bug will look into it.
  10. rohanpitre
    Eclair Jan 28, 2017
    Could you share the link please?
  11. rohanpitre
    Eclair Jan 28, 2017
    Well even I didn't know about the alarm thing. But as @ElRobertson mentioned that the phone gets stuck in boot loop, mine doesn't even switch on. Is there any minimum time for which phone must be switched off?
  12. ElRobertson
    I think it starts something about 2,3 minutes before the Alarm starts. So choose an Alarm in 5 minutes into future :)
  13. SpeedbirdMotorcycles
  14. butaixyz8016
  15. ziepicwaffle
    Ice Cream Sandwich Jan 28, 2017
    ziepicwaffle , Jan 28, 2017 :
    I personally like private kernel. Boefflas ok. You could try both and then choose the one that works better for you.
    butaixyz8016 likes this.
  16. G_Rohan_Patre_hiZT
    seconded! One of my favourite features from KitKat
    rohanpitre likes this.
  17. ElRobertson
    what's your Problem with the included Kernel? It gives me 6h +-30min SOT.
  18. luukbernardes
    Gingerbread Jan 29, 2017
    luukbernardes , Jan 29, 2017 :
    Which kernel do you guys think gives better battery life? Stock, intense, Private or Boeffla kernel?
    I've been using Boeffla for a while now, with Zzmoove battery plus governor
  19. butaixyz8016
    Honeycomb Jan 29, 2017
    butaixyz8016 , Jan 29, 2017 :
    I m getting only 3 hrs sot
  20. ElRobertson
    ElRobertson , Jan 29, 2017 :
    then make a clean install or remove unneccessary Apps, etc!
    On LegendROM I'va always had about 6h SOT from v1 until now at v11
