48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. Jakob1502
    Gingerbread Feb 8, 2017
  2. dema51
    Eclair Feb 8, 2017
    dema51 , Feb 8, 2017 :
    over the configuration that you mentioned, you use also other apps?
    like naptime or greenify?
  3. sathish D C
  4. Tarfex
    Ice Cream Sandwich Feb 8, 2017
    luukbernardes likes this.
  5. Jakob1502
    Jakob1502 , Feb 8, 2017 :
    Also why is it that only the buttom facing microphone is in use while recording a video?
  6. ziepicwaffle
    Ice Cream Sandwich Feb 9, 2017
    ziepicwaffle , Feb 9, 2017 :
    It depends what apps you use. I use greenify only because chrome sometimes runs wild in the background and a few other things. I also use all the apps that are really bad for battery (facebook, messenger, snapchat... :( ). Your usage may vary.
    I turn things like bluetooth and NFC off since i almost never use them. Location, i actually keep it on device only, turn off location history, and make sure wifi and bluetooth scanning are off under location. Lineage OS is nice in that it has privacy guard, and you can restrict apps from running in the background.
    If you aren't already, I recommend using wakelock detector. It requires root, but it shows you which apps are preventing your phone from sleeping and you can restrict those apps in privacy guard or greenify.
    jhalayashraj and luukbernardes like this.
  7. SpeedbirdMotorcycles
    Gingerbread Feb 9, 2017
  8. jhalayashraj
    Honeycomb Feb 9, 2017
  9. Jakob1502
  10. jhalayashraj
    Honeycomb Feb 10, 2017
    jhalayashraj , Feb 10, 2017 :
    UPDATE:- 12.0
    Changes:-
    Optimizations:-
    • Uber Optimization
    • Odex
    • Clang O3
    Legend Settings:-
    • Advanced QS Easy Toggle Added
    QS Tile:-
    • NFC Tile Added
    Other:-
    • Lockscreen Blur Added
    • Clear all text is now align with Free RAM
    • Lineage SetupWizard and Updater Removed
    • Synced with Latest LineageOS Source
    Full Changelog:- https://drive.google.com/file/d/0B7RVEiSSVecXYnZHbGh4cl80a1k/view
    Download:- https://www.androidfilehost.com/?fid=529152257862702017
    A clean flash is recommended if you are coming from any other ROM. Users who are on 11.0 can Dirty Flash.
  11. zedoc
    Cupcake Feb 10, 2017
  12. ZPasha
    Eclair Feb 10, 2017
    ZPasha , Feb 10, 2017 :
    Is there any way to switch off the lockscreen blur? The animation while unlocking the phone is gone because of that. Had the same issue in COS. And even setting a different wallpaper for the lockscreen doesn't bring back the animation.
  13. sathish D C
    Gingerbread Feb 10, 2017
    sathish D C , Feb 10, 2017 :
    In call volume is fixed ? And am in 11.0 flashed Google pixel and intense kernel its need to reflash this files while dirty flashing ?
  14. jhalayashraj
    zedoc likes this.
  15. jhalayashraj
    Go to settings/security/screen lock settings nd last option is for disabling lockscreen blur.
  16. jhalayashraj
    Yes its needed to reflash. Call volume should be fixed as commit regarding that is added but not checked yet.
  17. ZPasha
    Eclair Feb 10, 2017
    Thank you very much!! I appreciate it
  18. Tarfex
    Ice Cream Sandwich Feb 11, 2017
  19. jhalayashraj
    Honeycomb Feb 11, 2017
    jhalayashraj , Feb 11, 2017 :
    Magisk-v11.1 working fine with LegendROM-12.0
    Steps:-
    1) If you are using any superSu or phh's su first fully unroot
    2) Flash Magisk-v11.1 zip
    3) Install Magisk Manager from Play store
    4) Enable Magisk Hide in Magisk Manager Settings
    5) Disable USB debugging
    6) Reboot
    JayminVyas and ziepicwaffle like this.
  20. DNGeezy
    Cupcake Feb 11, 2017
    DNGeezy , Feb 11, 2017 :
    Hey, was Google Assistant support removed? I just updated to the latest version and for some reason I can't get assistant to work. Any help?
