48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. Tarfex
    Ice Cream Sandwich Feb 13, 2017
    Tarfex , Feb 13, 2017 :
    did your phone slow down after flashing Magisk? or was it only mine
  2. jhalayashraj
    Honeycomb Feb 13, 2017
    jhalayashraj , Feb 13, 2017 :
    Go and check in manage storage if automatic remove photos and videos is on or off.
  3. jhalayashraj
    Nop it's working fine.
  4. jhalayashraj
    Lol no offense but avg battery life is 4 hr that you can get easily. If you are not getting that thn maybe its your usage or your battery might damaged. Try clean flashing or flash any custom kernel.
    se7enlyn likes this.
  5. JayminVyas
    JayminVyas , Feb 13, 2017 :
    I have never tried this thing....but if this can hide root, it would be of great help. Say if we are clean flashing the ROM, we can start with step 2? And flash SuperSU only after all the remaining steps are followed?
  6. C0ntroller
    Gingerbread Feb 13, 2017
    C0ntroller , Feb 13, 2017 :
    You don't need to flash SuperSU afterwards. Magisk is by default like hideable root. You can add other modules later (eg Xposed if this ever will be a thing on Nougat).
    Anonymous_unknown and JayminVyas like this.
  7. Tarfex
    unroot, and then flash magisk and download the magisk manager app and then check to see if everything passes. make sure to turn ADB off in devolpee settings
    JayminVyas likes this.
  8. harshdangi
    Froyo Feb 14, 2017
  9. JayminVyas
    Ice Cream Sandwich Feb 14, 2017
    JayminVyas , Feb 14, 2017 :
    Thanks guys! You would have figured out from my signature - i havent flashed since a loooong time. Need to find some time and flash, now that root can be hidden! :D
    C0ntroller likes this.
  10. Kerttuurius
    Eclair Feb 14, 2017
  11. Kerttuurius
    Eclair Feb 14, 2017
  12. EdLikesBeds
    Gingerbread Feb 14, 2017
    EdLikesBeds , Feb 14, 2017 :
    It's already enabled. Go to Settings > Buttons then change the long press of home button to Search assistant. Long press the home button and it should ask to set it up.
  13. nightfly
    Froyo Feb 15, 2017
    nightfly , Feb 15, 2017 :
    So would andriod pay work in this scenario?
  14. harshdangi
    Froyo Feb 15, 2017
  15. Tarfex
    Ice Cream Sandwich Feb 16, 2017
    Tarfex , Feb 16, 2017 :
    ya I think it will. Snapchat works fine with this "hidden root" but I don't use android pay so I'm not sure.
  16. johnblane
    Cupcake Feb 16, 2017
    johnblane , Feb 16, 2017 :
    Ok... Sorry for the noob question. But after 1 hour of searching through the settings i come here defeated... How do you change the lockscreen wallpaper??? :(((
  17. akshansh2000
    Honeycomb Feb 17, 2017
  18. Sidhucs
    Cupcake Feb 17, 2017
    Sidhucs , Feb 17, 2017 :
    Phone keeps on restarting when cellular data is on... It reboots as soon as it reaches lockscreen.. the only way to stop this is to remove sim card and boot the phone... It works fine when connected to wifi. When cellular data is on, it goes into this loop... I'm on 11.0
  19. paull
    Ice Cream Sandwich Feb 17, 2017
    paull , Feb 17, 2017 :
    I'm gonna attempt to flash this later today but I would love to know a bit more from people who have it flashed. Does android pay work with the hideable root function? If it has the hideable root function or not.
    Also I'm on old cm14.1 nightlys for now and get around 3 hr sot with high/moderate usage would I get more on Lineage?
    Thanks
  20. Jakob1502
    Gingerbread Feb 18, 2017
    Jakob1502 , Feb 18, 2017 :
    I don't want to leave legendRom but for some reason my microphone is not working on this rom, it is working on sultan cm13 but I just don't want to downgrade to 6.0...
