48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. rsennat
    Donut Mar 18, 2017
  2. Max.Mar
    Jelly Bean Mar 20, 2017
    Max.Mar , Mar 20, 2017 :
    Nope. There are many re-basing in between these versions..its advised to clean flash or you might face bugs and in return you will be bugging this thread.
    Rutuj Gavankar and ElRobertson like this.
  3. Rutuj Gavankar
    Cupcake Mar 21, 2017
  4. jhalayashraj
    Honeycomb Mar 26, 2017
    jhalayashraj , Mar 26, 2017 :
    Major Update:- 14.0
    Changes:-
    Optimization:-
    • SDCLANG-3.8 Added
    • Cleaned up Older once and Dexpreopt
    Legend Settings:-
    • Custom QS Header Images
    • QS columns count configurable
    • Portrait/Landscape QS mod
    • Small QS tiles are scrollable
    • Dashboard Tile layout config
    • Wakelock blocker
    • Power + Volume up to Screen record or Partial screenshot
    • Bluetooth Battery Status when available (experimental)
    • Longpress Settings Button in Status Bar for Legend settings
    Pixel-ify:-
    • Pixel Lancer Added
    • Google Wallpaper Added
    • Pixel Accent
    • Updated Recents FAB Icon and color to Pixel Blue
    • Updated Recents Memory Bar color to Pixel Blue
    • Updated Power Menu volume selector color to Pixel Blue
    • Updated Legend Settings to Pixel Blue
    • Updated Gboard Theme to pixel blue
    Pixel Icons:-
    • Use Round Icons
    • Updated DocumentsUI, EmergencyInfo, StorageManager, Settings, Dialer Icons
    QS Tiles:-
    • NFC Tile Added
    • Assist and Voice assist Tile Added
    Substratum:-
    • ThemeSafety: Introduce App Crash Intent
    • Updated PackageInstaller, Contacts, PhoneCommon, ExactCalculator, Dialer, ContactsCommon to work without any error with any Substratum Theme
    Other Fixes and Features:-
    • Flashlight is now brighter
    • CIFS and NTFS module is now enabled
    • Custom Tile App Added
    • Disabled Ambient Display by default
    • Updated Substratum Dashboard Icon
    • Magisk Manager Dashboard Added
    • Materialize MediaProvider Icon
    • New Power Menu Airplane Icon
    • Disabled package verifier by default
    • Fixed TaskManager Running Services
    Download:- https://www.androidfilehost.com/?fid=529152257862714539
    Clean Flash is recommended as the optimization is changed. Now for experiencing the smoothness clean flash 14.0
    Cheers. Happy Flashing. If you guys like my work you can donate me.
    photo_2017-03-26_23-33-44.jpg photo_2017-03-26_23-34-17.jpg Screenshot_19711108-064544.png photo_2017-03-26_23-33-11.jpg photo_2017-03-26_23-33-26.jpg
  5. kidorikko
    Cupcake Mar 27, 2017
  6. sathish D C
    Gingerbread Mar 27, 2017
  7. C0ntroller
    Gingerbread Mar 28, 2017
  8. trumpet78
    trumpet78 , Mar 28, 2017 :
    Can anyone please link me to the Intense Kernel - Legend ROM version people have been using? I've tried using the links people have given earlier in the thread but I just get file not found :( Thanks!
    Dendedanamekian likes this.
  9. butaixyz8016
    Honeycomb Mar 28, 2017
    butaixyz8016 , Mar 28, 2017 :
    Just one bug, couldn't install driver for v4a, keep showing the same driver installation msg after rebooting, any solution??
  10. C0ntroller
    Gingerbread Mar 29, 2017
    C0ntroller , Mar 29, 2017 :
    Can confirm this.
  11. Roshanghosh09
    Ice Cream Sandwich Mar 29, 2017
  12. jhalayashraj
    Honeycomb Mar 29, 2017
  13. jhalayashraj
    trumpet78 likes this.
  14. jhalayashraj
    jhalayashraj , Mar 29, 2017 :
    Just change selinux to permissive or go to viper settings and turn on developer mode and disable selinux and you will be good.
    also if you are using magisk thn install viper module from magisk manager download section.
    butaixyz8016 likes this.
  15. jhalayashraj
    just install substratum theme engine from play store and install any theme from play store that you want to use with it and apply.
    Roshanghosh09 likes this.
  16. kartike4u
  17. kartike4u
  18. Owen_mccollam
    Cupcake Mar 29, 2017
  19. C0ntroller
    Mhh.. too easy.. XD Thanks!
  20. jhalayashraj
    it's custom kernel so its going to do what every custom kernel does. But this kernel is not updated in while so u may not find the gestures after flashing this kernel. but if gestures doesn't matter to u thn flash. Or u can flash any other custom kernel.
    Yup.
    kartike4u likes this.
