48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. jhalayashraj
    Honeycomb Mar 29, 2017
    jhalayashraj , Mar 29, 2017 :
    working fine here.
  2. jhalayashraj
    Honeycomb Apr 2, 2017
    jhalayashraj , Apr 2, 2017 :
    UPDATE:- 14.1
    Changes:-
    • Updated Pixel Launcher O-3743572
    • Google Wallpaper google-wallpaper-picker-1-0-149781330
    • LTE Tile Added
    • Pixel Navbar Animation is removed (just for now will add it later and pixel Navbar is till there just animation removed)
    • Fixed Navbar Home button not getting themed
    • Fixed Bootanimation Themeable with Substratum
    • Fixed Font Themeable with Substratum
    • Updated with Latest LineageOs Source
    • Don't forget to checkout Updated Gallery :)
    Download:- https://www.androidfilehost.com/?fid=529152257862716299
    Clean Flash is recommended but if you are on LegendROM-14.0 you can dirty flash. If you guys like my work you can donate me.
    Cheers.
    Happy Flashing.
    ziepicwaffle and Sidhucs like this.
  3. ElRobertson
    Gingerbread Apr 2, 2017
    ElRobertson , Apr 2, 2017 :
    Battery in version 13 and 14 was significant not as good as in versions 10,11 and 12.
    Do you have an idea?
  4. jhalayashraj
    No change in kernel side from version 10 to 14.1 but if you are not getting good battery life give a shot to custom kernel.
  5. ElRobertson
    OK.
    But I was also getting a good battery life (6h SOT) with your kernel on the mentioned v10,11... and now about 4h SOT.
    Thank you for this ROM anyway, cause I like it very much.
  6. jhalayashraj
    Will try to improve battery life in future builds. But here you can take a look at my battery life with 14.1 stock Kernel.
    ziepicwaffle likes this.
  7. Tarfex
    Ice Cream Sandwich Apr 2, 2017
    Tarfex , Apr 2, 2017 :
    the ROM is lagging for me. my phone randomly freezes up and doesn't respond or takes long to respond. any way to fix this?
  8. jhalayashraj
    Honeycomb Apr 3, 2017
    jhalayashraj , Apr 3, 2017 :
    Which kernel or mod are you using ? Also tell me if you are using any theme ?
  9. Tarfex
    Ice Cream Sandwich Apr 3, 2017
    Tarfex , Apr 3, 2017 :
    @jhalayashraj I'm in stock everything. my phone is freezing randomly it's so annoying I think it's been happening since the last update
  10. jhalayashraj
    No problem here and no one is having this problem on group so it must be from your side i suggest you to do clean flash.
  11. butaixyz8016
    butaixyz8016 , Apr 3, 2017 :
    Stable, fast and decent battery life on 14.0, like this rom pretty much
    Dev keep up your good work
    Thanks
    jhalayashraj likes this.
  12. jhalayashraj
    Do update it to 14.1 if you are using substratum there are some fixes related to it.
    butaixyz8016 likes this.
  13. jhalayashraj
    Honeycomb Apr 5, 2017
    jhalayashraj , Apr 5, 2017 :
    Hello guys... LegendROM is now available for all OnePlus devices. I started from bacon thn added OnePlus 3/3T and now OnePlus X and OnePlus 2 also added in the LegendROM's Official devices list.
    PS: Still Bacon is gonna get updates first no matter what. :p
    Thank You for your support. ☺️
  14. Sidhucs
    Cupcake Apr 9, 2017
    Sidhucs , Apr 9, 2017 :
    mobile radio active over 4 hrs... any solution..? also google app shows keep awake over 7hrs
  15. saurav9070
    Froyo Apr 9, 2017
    saurav9070 , Apr 9, 2017 :
    @jhalayashraj Excellent update. Smoother and substratum works fine! Thank you! :)
    There is just one suggestion. If you could make all your upcoming updates into a incremental builds instead of a complete builds, it would be really convenient. We wouldn't have to restore apps and accounts everytime. This way we could get security patches and important updates and still have the phone as it is. Saves a lotta time. I guess it would be easier for you too to make an incremental build instead of a complete one. And people who need to come to the latest build can always flash the latest complete build and then the required incremental builds to get upto speed. Just my suggestion. Would really love to see you implement it. Keep up the good work. Cheers.
  16. saurav9070
    Froyo Apr 9, 2017
    Sidhucs likes this.
  17. ElRobertson
    Gingerbread Apr 9, 2017
    ElRobertson , Apr 9, 2017 :
    no, because clean flashing is much better for good battery life and beeing stable!
  18. jhalayashraj
    Honeycomb Apr 9, 2017
    jhalayashraj , Apr 9, 2017 :
    Ah are you using stock kernel or any custom kernel ?
    Also for google app go to privacy guard thn click on show built in apps from menu and find google app and turn off keep awake option. You can do the same for google play services too if it's draining your battery.
  19. jhalayashraj
    Um if you are using my ROM regularly you can dirty flash if you don't want to lose your apps and account. But there are going to be some major updates like 14.0 was you need to clean flash that just for better performance and battery life you can still do that update dirty flash but its somehow not gonna work as good as it supposed to be.
    I have some plans for OTA. But now as my exams are going on and 7.1.2 is almost here. I will first merge 7.1.2 and after that will add OTA Support (I will first try OTA thn will go for the Delta updates). I was not wasting my time on OTA Because I gave features and optimization first priority.
    Thanks for suggesting. Future builds are going to be awesome. Stay tuned.
  20. Sidhucs
    Cupcake Apr 9, 2017
    using stock kernel as of now... will try your suggestion. thanks for the reply
