48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. falcon26
    Gingerbread Apr 10, 2017
    falcon26 , Apr 10, 2017 :
    Is there any way to remove apps being installed by this ROM? I don't want the viper thing and the default browser. I just want 100% stock android apps.
  2. jenish112
    jenish112 , Apr 10, 2017 :
    Then why don't you for stock Lineage OS?
  3. EdLikesBeds
  4. ElRobertson
    ElRobertson , Apr 10, 2017 :
    simply use a root explorer and delete the app folder
    For Viper example delete: //system/app/viper4android
  5. Roshanghosh09
    Ice Cream Sandwich Apr 11, 2017
    Roshanghosh09 , Apr 11, 2017 :
    U can use titanium backup for uninstalling the inbuilt apps.
  6. jhalayashraj
    Honeycomb Apr 13, 2017
  7. ElRobertson
    Gingerbread Apr 13, 2017
  8. SpeedbirdMotorcycles
    Gingerbread Apr 14, 2017
    saurav9070 likes this.
  9. jhalayashraj
    Honeycomb Apr 15, 2017
    jhalayashraj , Apr 15, 2017 :
    i'm running out of time but will try to look into it.
  10. jhalayashraj
    ah can you tell me any ROM name that has the animation ?
  11. se7enlyn
    Ice Cream Sandwich Apr 15, 2017
    se7enlyn , Apr 15, 2017 :
    If I'm not wrong it was the that guy raja's marshmallow rom.... Can't recall the name of the rom though
    Edit: exodus rom
  12. jhalayashraj
    Honeycomb Apr 16, 2017
    jhalayashraj , Apr 16, 2017 :
    Ohkay will look into it.
    se7enlyn likes this.
  13. saurav9070
    Froyo Apr 16, 2017
    saurav9070 , Apr 16, 2017 :
    Yes. I do use your ROM regularly :). Oh ok. But since your ROM updates are the full ROM and not incremental won't it erase the apps and accounts even if I dirty flash?
    Yes. I understand updates like 14.0 need a clean flash. I don't mind that.
    Oh alright. Cool. Can't complain anything about features and optimisation. You've done a splendid job with that. Yes can't wait for 7.1.2! Eagerly waiting for the future builds. All the best for your exams. :)
  14. saurav9070
    Froyo Apr 16, 2017
    It was there in stock cm 11s. We had the option to change it in the settings.
  15. ElRobertson
    Gingerbread Apr 16, 2017
    ElRobertson , Apr 16, 2017 :
    You can dirty flash. The app's data (your settings, profiles, accounts) won't be deleted.
    But if there are major differentes between the old and new Apps, it can come to problems.
    ziepicwaffle likes this.
  16. saurav9070
    Froyo Apr 16, 2017
    Oh ok. Thanks.
  17. SpeedbirdMotorcycles
    SpeedbirdMotorcycles , Apr 16, 2017 :
    Liquid smooth had it in its last iteration ...
    Thanks !!!
  18. JayminVyas
    Ice Cream Sandwich Apr 21, 2017
    JayminVyas , Apr 21, 2017 :
    Does the OPX version include FM Radio?
  19. jhalayashraj
    Honeycomb Apr 21, 2017
    jhalayashraj , Apr 21, 2017 :
    Actually I don't know as i don't have opx but will ask in opx group and tell you.
    EDIT: yes it has FM Radio.
    JayminVyas likes this.
  20. jhalayashraj
    Honeycomb Apr 24, 2017
    jhalayashraj , Apr 24, 2017 :
    UPDATE:- 15.0
    Changes:-
    • 7.1.2_r2
    • Updated Kernel To 3.4.113
    Legend Settings:-
    • Notification Ticker Added
    • Allow Ticker to show music track info on new track being played
    • Added Location to Easy toggle
    • Apply Data tile quick toggle behavior also to mini tiles bar
    QS Tile:-
    • Live Display Tile Added
    • Advanced Location Tile Added
    • Location Tile: High accuracy state Icon Added
    Other Stuff:-
    • Pixel Navbar Animation toggle Added
    • Task Manager FC Fixed Finally
    • Removed Advanced Reboot from developer Options
    • Removed Trebuchet Launcher
    SQLite:-
    • Upgraded SQLite to 3.18.0
    Substratum:-
    • Hold volume up during boot to disable all overlays
    • Themes: Expose Keyboard Shortcuts Dialog
    • Expose Screenshot flash and background colors
    Download:- https://www.androidfilehost.com/?fid=817550096634764523
    Clean Flash is recommended for everyone.
    My Final exams are starting from this 27th April so can't update ROM till it ends. I tried to make 15.0 worth.
    Cheers.
    Happy Flashing.
